Questions for piercers
Mike Foster
>I have had an open form sitting around in the shop for a while that I turned after purchasing a Munro Hollower (love the tool). I turned this vessel fairly thin, just to test the hollower. I realized the walls got real thin at the base but finished turning it anyway and stuck it on the shelf with other pieces that didn't quite make it. I decided to give a go at piercing tonight since I had all the rig to do it (byproduct of my other life). It didn't take long to realize that , though the piece I was working on was fairly thin (1/8") this may be a bit more than what other pierced pieces are. Piercing is not impossible, just slow. Further down the vessel where it thinned out to about 1/16" piercing went much faster.
So, to all those with experience piercing.
How thin do you aim for walls?
How do you clean up the piercings once done (needle files?).
Do you bother to remove the burn marks left by the bur, or is this why so many pierced pieces are air brushed?
I'll post a pic of my practice piece after it is a little further on. I want to try a couple more things with it for fun.
TIA
Mike
