end grain sealer
end grain sealer
end grain sealer
John the woodturner
>Does anyone have a recipe for making your own endgrain sealer?
Re: end grain sealer
Re:Do you have an abundant supply of ....
JamieDonaldson
>...candle or canning wax? A pot of hot wax is an old technique for dipping the endgrain for sealing.
John the woodturner
>I have a whole bunch of candle wax, but was hoping to find a recipe that would let me paint it on like with the store bought kind, I will keep that in mind tho.
Thank you
John, check your e-mail address
>You have checked that you want an E-mail reply to your post, but your Earthlink e-mail address is refusing mail from WoodCentral. The bounced messages come back to me. :(
It's (mostly) none of my business, but Earthlink has always infuriated me with their spam-catcher filters that make people jump through hoops to get a message through, particularly when the message was requested by the Earthlink recipient. I don't know if that is what is happening to the automated mail from WoodCentral, but we need to fix this.
I suggest one of three solutions if you intend to use our e-mail notification feature: 1) Either make sure your Earthlink filter is set to accept mail from webmaster@woodcentral.com, or 2) use another e-mail address on another host besides Earthlink, or 3) don't check the e-mail notification box.
Sorry, I tried to get this to you by e-mail but your server is refusing mail from ellis@woodcentral.com, too, and I'm not even getting the spam filter intercept.
Thanks for your cooperation. You ought to create a profile for yourself, too, so you can use the nice new features of the boards.
Ellis Walentine, Host
>I've played around with various things but it turns out the endgrain sealer is just better. I buy it in quantity and then sell it back to the club so we all get it cheaper. My mind has gone blank but I think I get the 5 gallons from UC coatings. I would have to look up the URL. I pour it into an open container and then brush it on. I've heard of people using a chemical sprayer and thought about that but I don't really use enough.
Re: John, check your e-mail address
John the woodturner
>I'm sorry Ellis, I stuttered when I entered my email address, think I have fixed it now, thanks for letting me know, sorry for any trouble it caused.
John
John the woodturner
>Your probably right, I was just trying to be cheap I guess.
John
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>Paint works well -- think about it, the function of house paint is to keep moisture out; therefore, it will keep moisture in, slowing the drying process which is the function of end grain sealer.
To save money, use old paint or go to Lowe's or Home Depot and purchase some of their mis-tinted/returned paint. Usually $3-5 a gallon for paint that would cost $20-30 if you got to choose your color.
Jeff Brockett
>Several of us went in together and purchased a 55 gallon barrel of anchorseal. Worked out to $9.00 per gallon delivered. Used old drywall buckets to store it in. You can purchase from US coatings. Funny thing is the label states "freeze proof formula" followed by "keep out of cold temperatures.
>I tried paint, also glue, caulking, and roof tar. Anything that was cheap and seemed like it would work.
What I found was keeping the wood out of the weather, particularly direct sun and wind, was the best thing to slow down the loss of the wood. Getting it off the ground is next. Sealing the end grain isn't a cure all. It does slow down the loss to give you a little more time to get it to the lathe.
the end grain sealer really helps if you cut the wood into smaller blanks. When my logs start to check I saw them in half at the heart and then cut them into squares as long as the log. I start with 4x4 then go to 3x3 all the way down to 1x1. I store these in the shop. The endgrain sealer really helps keep the end checking to a minimum on these.
charlie belden
>Candle wax + heat source?
If the wax is melted in a double boiler - bottom pan with water - bottom pan directly heated - upper pan with wax in water - not in direct contact with heat source - all's well.
Pan with wax in direct contact with heat source - not so safe.
Other issue is dipping wet wood in hot wax - especially overheated hot molten wax.
Water + lots of heat = steam. Steam + hot molten wax = owie!
Ed Heuslein
>I've purchased several 55gal drums of Anchor Seal for one of my clubs in the past. You can get it either with or withour anti-freeze. The anti-freeze formula only costs a few bucks more so that's what I get. In a conversation with an Anchor Seal rep. a few years ago, the difference between paint and Anchor Seal is paint is made to breathe, Anchor Seal is made to NOT breathe. The idea of sealing the end grain with Anchor Seal is to prevent moisture from leaving the end grain faster than the side grain, thus reducing cracks/splits. Just makes sense to me. Safe Woodturning.
I got a 5 gal bucket
Jorge Casta�eda
>of anchorseal about 300 bowls ago and still have 2/3rds of it. For $60.00 or so, I think is a good deal.
It is an emusion of parafin and water if anybody knows how they do that, let us know, inquiring minds blah, blah ,blah.
Jorge
Katherine Kowalski
Katherine Kowalski
>Our club decided to purchase a 55 gal drum of end-grain sealer with anti-freeze. One of our members donated a pump, and we sell the sealer back to club members at cost, and store the drum at our Wood Bank location. (Members supply/bring their old tins, or other containers).
It's worked out pretty well, and lets our members buy a gallon at a time at half the price of what they'd pay in a retail store.
Katherine
Bill Neddow
>I have also played around with paint, paraffin and all the other techniques. Anchorseal just works better. What is the sense of saving a couple of pennies on coating and having the bowl crack? Anchorseal is knot a cure-all -- but I think my failure rate due to cracking went down about 20 per cent when I stopped using paint. Paraffin is dangerous (open flame and wax) as well as hot and messy.
JKJ in East TN
>I agree - anchorseal not only works better than most but is easier to prepare, and apply - no heating, melting, mixing, or brush cleaning needed.
This works best for me: I use a Folger's coffee container because it has the built-in hand grip and nice lid.
The best containers are the taller ones, but they are not always available in the grocery stores.
I pour a bit of anchorseal in the bottom and stick one of those 3" cheap, disposable brushes inside. This is easy to carry, easy to hold while applying (whether painting the end of a log or blanks in the shop), and the lid keeps it from drying out. Never have to clean the brush. If a brush does dry out, just flex the bristles on the edge of a board or something. For the short containers, the end of the brush handle may need to be cut off to fit in the container.
Jorge Casta�eda
>I just keep the brush in a freezer bag.
Bill Neddow
>I follow exactly the same routine, John -- including the same Folgers can (taller if I can get it)!
