termite tool question
nick
>I just got a Oneway Termite tool and it seems to work pretty well on walnut end grain but I don't know whether I'm using it right. The ring cutter has a larger diameter opening and a smaller one. Which one are you supposed to cut with? They both work but the smaller opening seems give a better finish. Any advice on getting a clean cut with this thing? I wouldn't say that it leaves walnut end grain so smooth that it needs only light sanding. On the other hand, maybe I just don't know how to use it yet.
Re: termite tool question
>You use it rubbing the bevel so it cuts. You can use either side. If one side cuts better than the other then it needs to be sharpened. Now that I think about it mine has 2 different sharpening angles but that may be because mine is old and has been sharpened too many times.
If you go to youtube and type in john59lucas you will see my video on how to use the Hunter tool. You can use the termite tool the same way. If you think of the cuts as being the same as just the nose of your bowl gouge then you will understand how it cuts.
Re:The Termite cutter has 2 different bevels, ...
JamieDonaldson
>... and use the cutter on the diagonal, never flat. There is a similarity in technique to using a hook tool, and requires a significant amount of practice to master and sharpen- that's why I retired mine long ago!
jim miles - Charlote NC
>Jamie:
Been using termite for years, I don't really find any differance in the 2 sides.
Keep in mind it is basically a gouge on the side. It does take a while to learn to use it well.
Dump the sharpening rig that comes with it and get a cone shaped dremel- you only need to sharpen it on the left side ( cutting side ) and the end.
It is billed as an end-grain tool- It really does not cut end grain well- unless youdrill a hole - then you are cutting side grain and it works great. I also use it often for finish cuts inside bowls. Good luck !
Ron Williams
Ron Williams
>I've used mine for years to hollow end grain for boxes. The first thing I found was that is was _not_ a bevel-rubbing tool. If you try to cut with the full bevel rubbing on the wood (with the ring facing up as you cut on the side wall), it will grab and catch - its very aggressive. Try presenting the tool with the ring pretty much vertical, but with the bottom edge leading enough to make contact with the wood first. Then slowly rotate clockwise until it begins cutting. With a little practice you find the angle that cuts well without grabbing - the closer to horizontal, the more wood it takes, but the grabbier it feels.
I tend to use the smaller ring, but I make small boxes. As others said, mine actually has two diameters - one side is a slightly smaller opening than the other. I don't know why, but I find the larger diameter works better across the bottom of the box (cutting end grain) and the smaller works better coming up the side.
Drilling a center hole to depth does help, but I've found with practice that I can push the ring in dead center on the bottom and start pulling to the side to cut the bottom without one. I use the larger-diameter side of the ring to accomplish this.
>you are correct in that it is not a bevel rubbing tools when used to clean up a sidewall of a box. That assumes of course that you have the ring tool mounted in the end of a bar. In that case it would be a bevel rubbing tool when cutting the bottom of the box and then as you move around to the side it becomes a scraping tool. I use the Hunter carbide tools this way.
However, if you mount the ring tool sideways or 90 degrees to the bar then you can use it as a bevel rubbing tool and bet a cleaner cut. This is really only useful for vases and hollow tubes because it would be too large for most boxes. The Hunter #1 tool is frequently used this way in a Lyle Jamieson swiveling holder. It lets you cut the sides very cleanly.
