What size picture can be posted, trial
Leo Van Der Loo
>Suggested max. size of 700 pixels is how big ??
Looks pretty good
Leo Van Der Loo
Looks pretty good
Re: What size picture can be posted, trial
>Nicer piece Leo. I used to use 600 pixels so this is a little larger which should show more detail. Not having to click on them to see them larger is a nice feature.
Brad Vietje
>Does look good, Leo...
I hope that's two pieces -- or you have a mighty long bevel on your spindle gouge and really tiny (and battered) hands!
Safe spinning,
Brad Vietje
Newbury, VT
>Brad I can't answer for Leo but I use a skew with the toe down to reach into those places. This is the one time I can't use my Thompson skew. It is simply too thick ( which is what I usually like about it). For reaching into tight places like that I use my thinner oval skew.
JKJ in East TN
>The optimum size would depend on the viewer's monitor, but most people have at least 1024 pixels across these days. Anything from 400-800 pixels across usually works well, depending on the content.
To answer the question in your subject line, there didn't used to be a limitation on the actual pixel dimensions of the uploaded image, just the byte size on the disk. Of course, a huge picture is usually too big to upload without extreme compression which can degrade image quality. However, the results can be surprising, depending on the image content (solid and smooth areas compress more gracefully than areas with a lot of "busy" detail). To test this once, I compressed a 2560x1920 test image to 79k and uploaded it. That size is hard to view but sure can show the detail. Let's see if it still works with the new forum software:
The test image at a useful size:
The huge image:
It looks like the new forum software limited the horizontal display width. (at least in the preview) The old software kept the entire picture in the thumbnail and allowed scrolling to view.
EDIT: I tested and the entire 2560x1920 image is still there, just part of it is displayed. You can right-click on the partial image and copy or save the entire image to your local computer. On my system, the forum limited the displayed size to around 795 pixels across so that may be a good upper limit for posted pictures to make sure people can see the entire image in a message.
Leo Van Der Loo
>It is a one piece Brad, just over 12" long, and no battered hands, learned to keep them away a long time ago
It wasn't easy, but that's what makes it interesting
Here's a look from the bottom side
interesting
JKJ in East TN
>Interesting that when I previewed the message and viewed it just after I posted, only the left portion of the huge image was displayed. Looking at the same message some hours later, the entire image is visible, reduced to around 790 pixels across on my screen. However, the entire image is still there and can be downloaded or copied. I wonder if something was changed in the forum software today or if it just changed by itself. Spooky.
