Home made tools
Home made tools
Home made tools
Don at Central Illinois
>I am going to try to make some Ellsworth type tools. I know he uses CA but I wanted to know if that is any better than silver soldering. Also, do we have any archives, etc. that give a small how to on silver soldering? As always, thanks in advance. BTW, Ellis, this looks GOOOOODD.
Re: Home made tools
Re: Home made tools
Bill Youngblood
>I've only done a little silversoldering, but I know it takes really high heat. The CA glue well release with relatively little heat. Good luck. :)
Re: Home made tools
Re: Home made tools
>Bill is correct. CA is not anywhere near as strong as silver soldering but then you don't need it to be. If you drill the hole so the tool is a snug fit CA will hold it quite well. Then if you ever need to replace it just heat the joint with a propane torch and pull the cutter out. With Silver solder you need first to buy the silver solder which isn't cheap. Then you need the flux and you will need a MAPP gas torch or oxy/propane to have a high enough heat to get the solder to flow.
Re: Home made tools
Steven Antonucci
Depends on your diameter
steve antonucci
>If you are using 3/8" or thicker round stock, you can tap a thread for a set screw. It makes it easier to replace tips (I have a small, medium, and large tip for better access and control)
I've also glued them in with CA, and it's basically, quick and easy. I suspect that if I were making dozens of these at one time, I'd want to do it quickly too. The glue holds plenty strong enough for hollowing.
I have brazed before, but I would be concerned about the cutter losing it's temper. It would be my last option.
Re: Home made tools
Re: Depends on your diameter
>Thanks all. I guess I was trying to make it harder than it needs to be. I'll order some drill rod, I already have some tips and try glueing. Again, thanks.
Re: Home made tools
>Don You don't need drill rod for this. The bar just supports the cutter. I just use cold roll steel from the hardware store for my boring bar tool shanks. Drill rod is handy for things like tool posts or tool rests where you need something a little harder or exact dimensions. It's also pretty handy if you make your tools from one solid piece and want to harden the tip after you shape it. If your going to add your own cutter like the Ellsworth and John Jordan tools then cold roll is fine.
Re: Home made tools
Steven Antonucci
Absolutely concur with John
steve antonucci
Re: Home made tools
Re: Home made tools *LINK*
Bill Turpin in WNC mountains
>Link is to WC article written several years ago. Silver solder has increased in price since it was written. I agree with the others that CA is good.
WC article
Re: Home made tools
Re: Home made tools
Don @ Central Illinois
>Thanks, John. You just saved me some money, actually I have some on hand. Maybe I'll try it this weekend.
Re: Home made tools
Re: Home made tools
>Don just for information sake. I use 3/16" hss square cutters. They fit perfectly in a 1/4" hole. I have used set screws to hole them in but they have 2 problems. Unless your using thick bars they tend to stick up a tiny bit. If you put them on the top they full up with shavings and you have to dig that out before you can use the allen wrench. If you put them on the sides you risk hitting the lip of your vessel when inserting. If you put them in the bottom they catch on the tool rest while inserting or removing the bar from the hole. Been there, done that, I prefer glue. On long or heavy bars that can make sharpening the cutter difficult then I use the set screw. I put it on top and just keep an ice pick handy to clear out the junk when I need to loosen it.
Re: Home made tools
Re: Home made tools
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
>This is just a nit, but I don't see why you can't make the set screw a tiny bit shorter than the hole so it won't stick out. John Jordan's tools are like that.
