Gesso
Paul Zerjay
>Is gesso thick enough to work as a grain filler? TIA
Gesso
Paul Zerjay
I would say yes in my experience
steve antonucci
Re: Gesso
Brad Vietje
>Paul,
Since gesso is designed to fill the gaps in surfaces like a stretched canvas, it should work well with a few applications. It is not intended to be clear, though.
Safe spinning,
Brad Vietje
Newbury, VT
Definitely
Mike Foster
>Gesso is often used as a base for glod leaf which needs to be glass smooth. From experience, one coat would probably do it to fill grain.
Re: Definitely
Tony - Memphis
>I've used it as a base for soem painted frames and such and it worked well. I did several coats and sanded. There are a couple of different types out there. One is labeled as "sandable." I guess it has more solids? Also, Jeff Jewitt wrote about using plaster as a grain filler. After you aplpy a top coat, the plaster is clear! It worked! Just for fun, I tried it on a piece of koa ( I made a small pill keeper for my wife) and it worked pretty well. I believe the article was in FWW.
Tony
Yes. You can even change it's color...
keith zimmerman, Normal IL
>if you want to. Just mix some acrylic paint into the gesso and you can achieve a pastel color. Been doing it for years, preparing canvas for paintings.
keithz
Re: Gesso
bob elliott
>In a class with Michael Hosaluk, he suggested the use of an old t-shirt to burnish the gesso if using gesso as your top coat color.
