Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
Guest
Red-tip Photina
>I am about to cut down some red-tip photinas around my house. I have never tried to use the wood, but do know it is extremely hard. Has anyone turned anything out of this stuff? I will have some pieces maybe 6 to 8" in diameter and a couple feet long. If it doesn't check, warp or degrade too badly I could use it in some smaller projects. I just would like someone else's experience to help me decide to keep it or chuck it.
Photinias (note the extra "i") are members of the Rose family and are in the same group as apples, pears, etc. (subfamily Maloideae; apple subfamily). The wood of these trees and shrubs are typically dense, small-celled, and with variable rays. As you might know, many of these "fruit" woods are prone to degradation when drying - often checking or splitting easily during the drying process.
I would treat the wood of your photinias similar to that of apple or pear with caveats of balancing the piece carefully, sealing end-grain, and ensuring a slow, gradual drying process. I might test some unsealed scrap pieces to get an idea of how rapidly the wood will check under your ambient conditions. Be sure to quickly seal fresh end-grain cuts to minimize the start of checks, and reduce setting up internal stresses if the wood won't be turned immediately.
Let us know how the wood behaves after you have used it a while!
>I turned some photinia from my sin's yard in Houston. It turned nicely(kinda like Bradford Pear) . I turned it green to about 3/32. It warped afterwards but did not split. I'd turn more if I could get it.
>When I first moved to Houston 23 years ago, Red-Tips were one of the most common plants used in landscaping. Probably one yard out of three had some Red-Tips, and many commercial properties had them also.
Since then, a fungus has wiped out most of them. Now they are seen in maybe one yard out of 30 or 40.
