Pyramid Tool - Why?
Pyramid Tool - Why?
Pyramid Tool - Why?
jake Niedling
>I just have to ask why add this tool to my collection? I read about its ability to make beads. I can make good beads with my spindle gauge and skew. I guess I need to see it demonstrated. Until then, I don't plan to add it to my wish list. Appreciate comments.
Re: Pyramid Tool - Why?
Mark Wollschlager
>I use them to make grooves, and undercutting ornament finial caps.
I prefer the 1/4" skew form of the same basic tool.
They are easy to make, anyone with a grinder can make one.
Mark.
I use my 1/4" round skew for those things
jake Niedling
>Jake I use it when I have to make a series of beads just exactly alike right next to each other. I have a beading tool but it only works for that size. Obviously I could make more sizes if I really wanted to. I can turn them with the spindle gouge but there's always the chance of taking off just a little too much here and there. With the 3 point tool I can clean up the shape quickly and safely. I don't use it often because I'm quite good with the skew and spindle gouge. But every now and then it's just the perfect tool for the job, and so easy to make.
Steven Antonucci
it's a "safe tool"- anyone can use it.
steve antonucci
That's why Jake needs it. :)
Re: Pyramid Tool - Why? - It works well! *LINK*
Mike Brazeau
>I was intrigued with the idea of the tool for years dating back to rec.crafts posts about it. Finally and after the article appeared in American Woodturner in '05 I believe, I made one. As John Lucas says, it is low risk and once you know how to make a bead with it (start from bottom and work up)it is bullet proof. I do a couple of beads and some texturing on the side of a bowl in 3-4 minutes. Couple of beads on base of bowl in similar time. My first was made from a shock absorber about 7/16" in dia. and second with 1/4" drill rod. Now use the 1/4" most of the time. Did a lidded box at hands-on the other night and dressed a lid up with a couple of beads and touched up some end grain cuts as well, no effort and no risk to something that was almost finished. Some photos in link below. I have seen the the commercial version from one of the Sheffield factories and it is way to big IMHO. I love the thing!
Check out My Tools & Jigs
Because it's easy to make. I wouldn't buy it.
Craig Daymon
>If you don't like it, grind a different end on it. If you use a brass hex nut for a ferrule, just lean every other facet against the grinder rest for easy sharpening.
Tony - Memphis
>I bought one thinking it would be a little easier for me to make beads. I'm not a turner. I build furniture and need to turn a leg now and then witha bead here and there, so I am not great with a gouge, or any other tool for that matter! I've had decent luck with the tool, but I need to practice more. Any tips?
Thanks,
Tony
HeatherA in AK
>OK, you lost me with "start from the bottom up". Can you explain this in a little more detail please.
Thanks,
Heather
>Tony For furniture type beads it's hard to beat a skew on it's side. At least for a new turner. For smaller beads the 3 point tool works pretty well. When I first started turning it was mostly furniture parts. I turned most things with the skew but used it as a scraper. I didn't know any better. It's still a handy tool used like this on occasion.
>Heather This tool is used with one of the bevel up so your looking at the flat part. there should be a V toward the bottom. You push the tool in and then as you pull it back out you drag it around the shape of the bead going from bottom to the top of the bead. This is backwards from the way we are taught to do with a spindle gouge or skew. With those you go from the top to the bottom.
Somewhere I have a DVD that shows the techniques. I'll have to look. I may have lost it. It used to be on the AAW website but I can't fine it anymore.
Cleaning up goblet bottoms.
>It's also handy for cleaning up goblet bottoms. You have to rub one of the bevels rather than using it as a scraper. By rubbing one of the bevels you can push it in and it cuts a lot like a skew with the toe down. I still use the skew but it's easy to teach people to use the 3 point tool.
It can also be used to face off the end a dowel using the same technique.
Thanks for the response, but....
Jake Niedling
>I am still not sure I need one regardless of what John Lucas says about my turning skills. LOL. I guess next time I visit you John, I will try yours out. Seems like it is still acting like a scraper, so I don't see how you get clean cuts rather than some tear out.
HeatherA in AK
>John, I found this one on you-tube that sounds like what you described. The point tool use is at the end.
Heather
point tool use
Ric Taylor
Even a Cave Man?
Ric Taylor
Re: Thanks for the response, but....
>Jake it depends entirely on how you rotate the tool. If you rotate it so that you have one of the sides touching the wood then it acts as a bevel and the edge acts more like a blunt angled skew. It cuts pretty clean this way. If you use it with one of the flats up and you do not have one of the bevels rubbing, then it acts more like a skew laying on it's side.
>Jake, I have a couple you can borrow to try out.
I ground one with an extreme point, not with three-way symmetry but with one face slightly concave at a relatively angle to the axis and the other two faces symmetrical making a rather sharp point. The think is wicked! It is great for getting deep into a narrow groove. I saw one made sort of like this but not as extreme. I should take a photo.
karl jr
It works great
karl jr
>for grooves in the bottom of boxes.
I just learned that today.
