New tools
New tools
New tools
Mike Foster
>Made a few tools today and thought I'd share them. This is a 3 point tool used for creating beads and grooves. Frank Penta made the tool and showed me it's use at John C Campbell this summer. It is a wonderful tool to use to make beads on larger pieces like bowls and hollow forms. Check out his website if you want more information on how to make the tool and use it.
http://www.woodspriteturnings.com/sites/penta/
Someone here posted his take on using a compression fitting to make a removable handle (don't remember who, but thanks!). I got the parts months ago and just got around to making a handle (I had been using the tool with no handle). I drilled out the handle with a 9/64" drill as far as it would go. Found the compression fitting shown (3/8 to 1/4) and decided that a teflon sleeve would work better than the brass one. I was worried that a brass sleeve could get compressed onto the tool and then not allow the tool to slip in and out. The fitting works as a great ferrule that, once sized, allowed the pipe thread to cut it's own thread as it is twisted on. Works great.
Re: New tools
Depth guage
Mike Foster
>Another tool that I found on Frank's site. It is something I have always intended on making and seeing it on his site game me the kick in the butt I needed to make one. This will handle an 18" bowl.
Re: New tools
Foredom holder
Mike Foster
>I use my Foredom a lot and find that I need it at different heights depending on the handpiece I'm using and the size of the piece I'm working on. I know you can buy portable holders with variable height, but I only use mine at the carving station with the downdraft table. You can't see it in the picture, but the bottom of the 3/8" rod is in a block of wood with a hole attached to the table and the top is another piece of wood that I used pocket screws to attach to the post. I previously had the foredom hung off of hooks attached to the post. This bracket gets it out from the wall closer to where I use it. I used a piece of purple heart for the hanger and used metal taps (1/4 x 20) to accept the thumb screws.
Re: New tools
Re: New tools
>Mike, I made a three point tool also, but I just use the nut as a Ferrel and glued the shaft of the tool into the handle. I have the tip/facets on the tool lines up with the nut so that three facets on the nut keep the angle correct on the grinder. I colored them black. Works great.
Re: New tools
Re: New tools
>Cool Mike. I'm still trying to design my rotary tool holder. I have a Foredom, a Weecher and numerous dremels. I'm thinking about making some sort of rotary holder that will let me move the one I want to the front. The ones without the flex shaft can just go in a drawer if I ever get around to finishing my carving bench.
