200+ woodworking book reviews
Wet Pen Blanks
Wet Pen Blanks
Wet Pen Blanks
BradH
>I recently purchased a 1.5" by 1.5" by 1' block of redheart. The wood has a very nice dark red color. After cutting this down to .75"x.75" pen blanks, the interior wood seems very wet, but I do not have one of those gadgets to measure the exact moisture content. First question, for pens, does the wood need to be relatively dry? If it needs to be dry, can I speed up the drying in a conventional oven? If so, what temp and how long for the .75x.75 inch blanks? We do not have a working microwave oven, in case anyone suggests to use a microwave.
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Philip Duffy
>If you go up on the International Penturners Ass'n web site you will quickly learn that many people will use only very dry or even stabilized wood blanks for nice pens. I commonly dry small pieces, like blanks, in the microwave, wrapped in a paper towel. Just start slow with low power, 40 seconds, about 10 minutes between cycles until the precise weight is stable. You have to let the wood cool between cycles, at least a couple minutes or it will burn. I keep hearing that the kitchen oven is just not the way to go. Good luck! Phil
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Carole Valentine
>Phil, me thinks you missed the last sentence of his post, maybe? LOL
Brad, sorry, I can't help with conventional oven drying, but you would be wasting the wood if you make pens with it while it is wet.
Re: Wet Pen Blanks
Rob Wallace
Re: Wet Pen Blanks *LINK*
Rob Wallace
>Brad:
I remember reading in one of the woodturning magazines not too long ago (maybe Woodturning Design? - does anybody remember where?) of a pen turner who built a small drying kiln around an incandescent light bulb that was used to dry pen blanks. Like any other wood, you should avoid drying redheart too fast (be sure the endgrain is sealed to reduce the possibility of checking); in my experience it is not as prone to cracking as other woods might be, but it still is a tropical hardwood. I would do some searching on the International Penturners web site* (or ask a similar question there?), since I'm sure others there have crossed this bridge before - if not for redheart specifically, but with other similar woods in the same condition.
I agree with what has already been said - you definitely don't want to turn the pens while the wood is wet/damp - it WILL be a waste of time, wood, and supplies.
Rob Wallace
*International Association of Penturners
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Terry Quiram
>Brad
Do not dry in a conventional oven! I also dry blanks in a microwave. For a few wet blanks I start at 20 seconds on high. I remove them and wait until they have completely cooled. Repeat until dry. Do not hurry or you will have charcoal(damhikt). I usually let the blanks stabalize in the shop for a couple of weeks after they are dry. My advice is to practice first with something you won't mind destroying until you feel comfortable with the process.
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Gary Evans--Tallassee TN
>Brad,
Since you don't have a microwave, get a box, put a single 20 watt light bulb in it. Seal the ends of the blanks and put them in the box. Cover the box. If you really want to get sophisticated, put a thermometer in there and don't let the temp go over about 80 degrees. If you want to get really, really sophisticated, you could do an oven-dry test of the moisture content of one of the blanks, but it probably won't be usable after you dry it to 0% MC.
You really need to be able to weigh the blanks before you put them in and occasionally as they dry. Once they cease to lose weight, they are dry.
I don't think you risk much chance of degrade doing it this way. A blank that is .75"x.75" doesn't generate as much internal stress when it dries as a blank that is 12"x12". Still, I would check them carefully on a daily basis and take them out if you begin to see checking.
Gary
Re: Wet Pen Blanks
Re: Wet Pen Blanks
>Why don't you go over to WoodWeb and post this question? ( different site that provides info about timber practices, cutting, milling, kiln drying etc.)
It is common practice to take a sample of wood from a load in a kiln, weigh it, dry it to zero in an oven and weigh it again and then do a calculation to see what the Moisture Content (MC) of the original sample was. This is used in kiln drying lumber to determine the MC and may still be considered more accurate than a moisture meter. WARNING: in this process they are not trying to dry the sample in a way that yields a useful piece of wood, they are just cooking the water out of it and don't care if the sample is destroyed. It's the balance of the load in the kiln they are worried about, not the sample. But there may be somebody on WoodWeb that can tell you how to dry a small piece of wood quickly and produce a usable piece.
I have never made a pen, so the rest of this is just rambling thoughts. Perhaps you should stop reading here. I would try one of two things. I have a scale. I would weigh one of my blanks with the ends sealed. I would heat my oven to as low as it would go, less than 150, Turn it off put the blank in there and wait until the next day. Weigh it again. Wait several days and weigh it again. If it has not lost any more weight, go ahead. Notice I said I would only risk one blank doing this.
Another thought, Drill the blanks and cut them down to size. Let them sit around and dry. Smaller pieces dry faster than bigger ones. Pieces with holes in them dry faster. Again, you need a scale to tell when they have stopped loosing weight. You would also need to be able to redrill the holes because they will shrink along with the blanks.
Alcohol drying might work too, Contact Dave Smith about that.
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Ken Oakley Sunny- Sunny St. Cloud, Fla
>I cut and sell on eBay hundreds of pen blanks a week. Most all my wood is scavanged or salvaged. The really wet stuff I cut close to finished size and fume them with ammonia for 24 hours. Then I will soak them in denatured alcohol for 24 hours. Place them on old refrigerator racks till the majority of the DNA has evaporated then turn on a 30" fan and let them sit till dry. Most wet woods I get dry in 7-10 days. I then cut to the finished size of 5 1/2" long by 13/16" sq. I still get a few that will crack. They are given as Freebies to people who win the bidding.
Re: Wet Pen Blanks
Katherine Kowalski
Katherine Kowalski
>Brad, your pen blanks will need to be dry before you can use them. I would recommend drying them in a drying box/kiln, WITHOUT drilling holes first. (If the wood moves, the holes will not be straight, and the tubes will not fit.)
Cindy Drozda has an excellent article on her web site about building a drying box. I recently built my own out of an old refrigerator, but you can make something much smaller, such as using the construction foam she suggests for smaller scale drying. (It's an easier project than taking time to convert a fridge/freezer).
Make sure you seal the endgrain of the pieces, plus a little up the sides. If there is wax on the side grain, I would either scrape it off, or add wax to the other two sides to help the piece lose moisture evenly.
Katherine
Cindy Drozda's Low-tech Drying Kiln (PDF)
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Dick Coers
>You've had lots of advice, but thought I would add my favorite way to dry pen blanks. I put them on top of the main trunk line running from my furnace. Burls and exotics start about in the middle of the house, and work their way to just near the furnace. It's a very gentle way to dry, since they warm up and cool off with every furnace cycle. In this cold (Cental IL), they will be dry in two weeks. Maybe you won't mind the furnace running so much if you are also drying wood. But if you live in Florida, go with the microwave.
Re: Wet Pen Blanks
Re: Wet Pen Blanks
Philip Duffy
>and you had to point that out? Maybe the you could loan him your microwave.
Re: Wet Pen Blanks
Re: Wet Pen Blanks
CGelnett
>Ken why do you fume them with ammonia? I use the DNA all the time but never heard of fume wood with ammonia
Thanks
Re: Wet Pen Blanks
Rob Wallace
Re: Wet Pen Blanks - FUMING??
Rob Wallace
>Hi Ken!
I am also curious about the reason for your ammonia fuming while the blanks are still wet. Are you trying to deepen the color/grain contrast of the wood? If so, how deep into the wood does the effect of fuming penetrate (In my experience, fuming is mostly a surface phenomenon.) This is the first I've heard of the procedure. I also go through the denatured alcohol step prior to drying many rough turned items (...but refuse to call it "DNA" which is an entirely different material!) and for me the alcohol treatment works fairly well.
If possible, could you explain the role of ammonia fuming a bit more?
Thanks,
Rob Wallace
