router jig for a John Jordan look?
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
>I've watched a demo by John of him carving his classic spiral shape onto the outside of a hollow form. He does it all by hand and says he prefers it to any kind of a more perfect machine look. I did one his way (actually straight down the form -- not in a spiral); and, needless to say, it was a lot of work. I thought I would keep going, this time with a spiral -- or some other design -- but I would like to take advantage of any jigs that are out there to make the work, at least at the beginning, less laborious. Does anyone know of any such contraptions?
Re: router jig for a John Jordan look?
>One of our turners built a spiral carving jig out of plexiglass. He heated sections with a heat gun until he got it the shape of the vessels he was doing. Then cut a slot in it for a guide bushing that fits on the router. I don't remember how he attached it to the lathe but it shouldn't be hard to rig up something to the tool rest or the lathe bed. You will have to make all of your hollow vessels with this spiral the same shape however.
Of course there are cable driven spiral cutters. I have plans for one made from bicycle parts in one of router books. I have done some router carving by hand on vessels using my flat router table that fits in the tool post. It gets a little tricky doing that and you have to go back and fine tune the edges. I used it waste away material to a certain depth rather than trying a spiral.
Rick_Allen
>Hey Eloit,
Stuart Mortimer uses an Arbortech cutter on a 4 1/2" grinder hand held. I saw this at the Road Island symposium. With the grinder in one hand he would pull the grinder through the wood as he rotated the handwheel (workpiece). He had the spirials well defined in a couple of minuites.
If you want to try the grinder let me know before the next meeting and I will loan it to you for a month. If you are in more of a hurry we can arange for you to pick it up anytime you like.
I have only seen this process I never actualy tried to do it.
>Stuart cuts all the way through usually. To simulate the depth that John J gets rotate the guard to your grinder so that it rubs the wood. This will act as a sort of bevel to help you control the depth of cut. You use the handle of the grinder like you would use a turning tool. Raise the grinder and it cuts deeper, lower the handle and it cuts less.
Don't remember who I learned that from but it's been one of the handiest things I've learned when using the angle grinder and the Arbortec or lancelot cutters.
Rob Wallace
Rob Wallace
>I can see using the router to make the top of the head....What would you use to make the moustache?
>That's funny! Not bad. I left my self wide open for that one.
John Jordan
>It's not THAT funny. :)
John
>Rick, Thanks for your offer. You are always especially helpful on this site. I'm having a bit of trouble, though, picturing the method you describe as being safe and accurate. I have the feeling, at least in my hands, that a fair percentage of the time I would be ruining off the line. I like the idea of something like the plexiglass router jig , but I'm having trouble with that idea, too, namely how to make it and set it up. At least Jordan's method of carefully carving down the spiral with a reciprocating carver will probably not result in wandering off the line and ruining the piece. I want to think about this some more.
Rob Wallace
Rob Wallace
>Wouldn't have commented if I didn't love ya John!
R.
