Settings for chainsaw sharpener
Aage Rendalen
Aage Rendalen
>I sharpened a couple of chains yesterday on my Harbor Freight machine, using a 30 degree horizontal and 55 degree vertical angle. Not very impressed with the result. Of course, I was rip cutting slabs so that may have had something to do with it. What settings do you others use?
Re: Settings for chainsaw sharpener
Dave (PacNW)
>Without seeing your saw chain (hold it closer to the computer), It is hard to diagnose your problem. I ran a logging supply here in the Great N .W. for several years and have sharpened literally thousands of feet of saw chain. I would suggest you get a piece of new chain( same type you are using) and study it for the top,side and front. Looking at the top the angle is 25 to 35 degrees (depends on chain type). The top angle is mirrored on both sides. The down angle(cutting angle) is determined by two factors 1) the angle of the Cutting wheel 2) the off-set from vertical( 25 to 30 degrees). When you look at the side of the cutter, you will see a distinct shape on the top down about 1/4 of the cutter. This is determined by the depth that the sharpening stone is set too. The other factor is the raker set. This is the small hook in front of the cutter and needs to be set every sharpening to .030 to .035 below the leading edge of the cutter. Both of the cutters( right and left) need to be the same length. You can use a regular chain to rip but they make special ripping chains that work much better for slabbing up a log.
Good Luck,
Dave (PacNW)
Rick in Colgate, Wi
>For ripping I have one chain re-ground to 10 degrees or less on the horizontal angle. This grind can really kick back so be extra careful!
