? on drive belts and availability
David Churnega
>I have an old Delta Wood Lathe that I believe to be a 46-230.
The drive belt is not marked and I want to know when it is neccessary to replace. It wobbles considerably on the lowest speed (480?). Is it time to replace and where can I get one?
Re: ? on drive belts and availability
Brad Vietje
Brad Vietje
>Hi David,
Beautiful old machine. Should be no problem getting a new belt. In my experience, these are standard V-belts, and all you have to do is get the right size. The length can be a little short, but not too long -- you can move the motor up a bit if you use a slightly shorter belt.
Many of these lathes use a hinged motor mount (motor bolted to a board which is hinged), so the weight of the motor supplies the belt tension, and changing belts is accomplished by simply tilting the motor "up", and then back down, so the motor "hangs" from the belt.
These have easily-replaced bearings, too, so an older lathe like this is a good machine to work with (and for my money, better than most of the newer mini's on the market).
Safe spinning,
Brad Vietje
Newbury, VT
...learned on an old Rockwell Delta a lot like yours.
David Churnega
>Thanks for the info on the motor being hindged to tension the belt. It is not currently set up that way. But it will be.
Gordon Seto
>David,
You may also want to consider Link belt. It may make the lathe runs smoother.
Gordon
Brad Vietje
Brad Vietje
>A-OK, David,
You will want to be sure you get enough tension that way, and probably install some sort of stop to prevent the motor from lurching upward too far...
There are many opinions about belt tension. I prefer the belt to slip if there's a bad catch, which I believe is safer. I would opt for a little more tension when doing something demanding, like coring bowls, but I still prefer a little more slip than some people. My completely non-professional view is that belts are cheap, and arms are expensive to replace! Just kidding, of course, but I think safety is enhanced when the belt and the drive center can slip instead of contributing to a dangerous catch-related projectile incident.
I like using a dead cup center in the headstock for spindle turning (instead of the 4-prong centers driven into the wood) for the same reason -- they will slip when something goes wrong, which is far less frightening, and provides an opportunity for learning instead of bandaging. This is especially good for beginners and teaching.
Safe spinning,
Brad Vietje
Newbury, VT
