air compressor
air compressor
air compressor
olejon
>my air compressor went out yesterday i wont to get a new one dont know witch way to go could someone recommend one 20 or 30 gal my old one was a sears i know this dont sound like a big deal but im 69 year old geting this thing up hill to my shop is a big job for me i just wont to do it one time some day i will learn how to post pictures on here show you some of my turnings thank for your help
Re: air compressor
Re: air compressor
Bill Crommett
>One thing: Don't get an oil-les compressor unless you can put it far enough away that the terrific noise doesn't deteriorate your hearing worse than it is now.
Re: air compressor
Re: air compressor
Bill Howatt
>Like the other Bill says, don't get an oiless.
Do you need one as big as the old one? I have a 25gal compressor and something like a 3.5 gal compressor. I mostly use the small one when turning to blow the dust and shavings out of turnings or to blow off the surface. I now have the big one in the garage since I don't need it in the shop.
Naturally, you may have much more use for a larger compressor than I do.
Bill
Re: air compressor
Dick Hines
Re: air compressor
Dick Hines
>Get the biggest one you can scrape up the cash for. I am on my third one and the next one will be a oiled one.
Re: air compressor
Re: air compressor
Pete in Holland, MI
>Check the CFM rating of the old unit. This is how much air it puts out. Tank size only indicates how often it will fire up.
If the old one put out adequate air for your needs, that is the size you need. If you often starved it, or it rarely fired up, you might be able to up or down size.
Regarding getting it to your shop, a couple beverages will often be all that is needed to recruit some help from neighbors & friends.
Pete
