Finish for hard maple bowls?
Dave Mount
>Because it is readily available to me, I've been turning a lot of hard maple bowls. I rotary sand to 800 grit on the lathe and this brings hard maple to a nice polish even without finish. However, when I put Danish oil on it, it seems like the wood is so polished that it takes up very little finish. After the oil dries (what little is absorbed), I've been using buffs with tripoli, w diamond, and carnuba.
All this makes a pretty bowl, but the problem seems to be that there's so little protection that any moisture at all creates pronounced water spots and rough spots like raised grain. I've also tried Shellawax cream, but it seems to suffer from similar problems -- a pretty finish when it's fresh, but easily damaged even from just casual moisture on peoples hands.
I'm about to start experimenting with film finishes, but before I do, I thought I'd ask for any pointers. I'm looking for something appropriate for a bowl that lies between a purely display piece and a salad bowl -- a bowl that can hold something like chips or nuts, then be wiped out with a damp rag without suffering too much, but nothing so severe as sitting with something wet in it.
Should I be pre-raising the grain with water somewhere in the sanding sequence? Should I stop sanding at a lower grit to leave more "texture" and enourage more oil to stick? Or should I just go to film finishes (and if so, which)?
Suggestions appreciated,
Dave
