Pens for signing turnings?
Dave Mount
>Sorry to ask such a dippy question, but I'm struggling to find a pen appropriate for signing the bottom of turnings. I'm a flatwork guy that only recently started turning. On case pieces I sign somewhere inconspicuous in the interior or the bottom, usually in pencil with a light coat of finish over it (pencil because it does not bleed into finish). However, pencil seems too lame for a turning, there are no inconspicuous places on a bowl, and even on the bottom the lettering on a bowl sees some handling and wear.
I guess a related question is when in the finishing process you sign (e.g., before or after buffing/waxing)?
Thanks for any pointers.
Dave
Re: Pens for signing turnings?
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>Dave,
I label my items using a Sigma Micron pen with archival black ink. These pens are inexpensive, and available in different diameters and colors. They can be purchased at Michael's, Hobby Lobby, various office supply stores and from Amazon, where they are really inexpensive.
Write on the wood after it is smooth but before applying sanding sealer or any other finishing agent. The ink penetrates and dries quickly so you can apply chemicals after a minute or so. The ink is supposed to last for a hundred years or more.
Re: As a photographer I found that a....
Jamie Donaldson
>...Staedtler Lumocolor would write on just about any surface, and I sign the bottoms after sanding sealer is sanded/rubbed out(usually lacquer based) and before the final spray lacquer finish. Regular old Sharpies (Ultra Fine Point permanent)work just about as well when they are fresh.
Sigma
Carole Valentine
>I'll second the Sigma Micron. You can get them incredibly fine for signing very small places, they don't bleed when you apply a finish and they use archival ink.
Sigma Pen is my vote as well, before finishing
jake Niedling
Dick Hines
Dick Hines
>If you go an art supply store they have pens. that are very fine and will wright on most everything. I picked up some this fall that were .25. As far as I know they only come in black. I use then to sign ornaments.
Sorry I can't remember the nmae. They are out in the shop and I am in the warm house.
Rob Wallace
Do pyou mean PIGMA or Sigma? *LINK*
Rob Wallace
>I use a 0.45 mm PIGMA black archival pen for signing pieces. Is this what you mean? See the link!
Rob Wallace
Pigma ArchivalPens
Re: Do pyou mean PIGMA or Sigma?
>Rob, yes, I meant Pigma. There is a Sigma pen but Pigma is what I meant to recommend.
Right...PIGMA
Carole Valentine
>The print is so small I couldn't read it!
Oh, and they do come in colors - I use them to draw on Holly. I think one of the ones I use is .005 microns.
Re: Thanks -- we even have a Pigma already!
Dave Mount
>Turns out SWMBO had a 0.45 Pigma Micron pen in brown in her stash of pens. I'll give it a try!
Thanks again,
Dave
Tom Stevenson
>I have always used India Ink and a steel pen. The surface should be smooth to make writing easier. I put at least one coat of finish on the wood first. After signing I put another coat of finish. I have not found a finish that will disolve the dried India Ink. And as a bonus, if you spell your name wrong, a little water and you can try again. (Water removes India Ink and cleans the pen.)
