Finial Forest- anybody here playing with....
JamieD
>...finial variations these COLD days? I usually keep a stash handy for quick fitting to vessel projects, and make them in batches because they're "entertaining!" Don't know what I'll do with the multi-axis turned specimens, and also experimenting with finishes other than shiny black, meaning woods other than expensive ebony and blackwood..
Re: Finial Forest- anybody here playing with....
Re:Here are some color variations, and.....
JamieD
>..the metallics are made using Rub-n-Buf pastes applied while spinning.
John Cotten
>Great work as always Jamie. Stay warm. It sure is cold here in Harrodsburg.
Texian
>No, but could/should be doing that while waiting for glue to dry. Mine are not awful, more like mediocre, and need more practice. I like the multi (2?) axis on the far right of your picture. Many pieces might be better served by a natural wood finial rather than the ubiquitous black. Some of the metallics could work on the green and rust finish pieces. Just some thoughts on a cold evening here too.
Steve Kubien
Steve Kubien
>No Jamie, I'm turning finials en masse but I think that is a fantastic idea! Oh ya, I will be setting aside time to do this.
Steve
Very cool Jamie!!
Dave Peebles Lyons, Ohio!
Cyril Griesbach
>Very nice finials, Jamie, and I like the color variations as well as the off center designs. I usually turn my finials into firewood or should I say fire starters.
Carole Valentine
>Jamie, what are you using for the gold, copper and silver finishes? I have tried the Rub 'n Buff stuff but never was satisfied with the results.
Steven Antonucci
Promise in this idea
steve antonucci
>If I was messing with this stuff, I'd make all of my tool handles look like that. Nice effect.
s
doug williams
>Nice color combinations, adds a different flair to different possibilitys of other work. Thanks for posting, and for the invitation. Where is this compound available. Doug
GalenV in Iowa
>Jamie
I bought the gold leaf Rub-N-Buff at Hobby Lobby to apply to some turned Christmas ornaments. I tried to apply while the piece was turning but ended up with applying stationary with a very fine soft brush and then when dry buff with a tissue.
Did you apply while turning at a high speed or low?
When I did it seemed to pull some spots back to bare wood. Touch not right or speed.
I had better luck with a coat of spray lacquer sanding sealer and very fine 600 grit sanding first. Did you apply any precoats first?
Wish I could produce more detailed finial but learning SLOOOWLY.
Only multiaxis I did was when I got a catch!
Yours are great.
Galen
Re:Carole- I found that application of ....
Jamie Donaldson
>...Rub'nBuff with a paper towel at slow speeds is the trick, and faster speeds cause it to flake off. The surfaces have to be well sanded but w/o any sealer for the stuff to stick best.
Re:Doug- I generally buy Rub'nBuff...
Jamie Donaldson
>..at Michaels art supply type stores, and it comes as a paste in small tubes, and a wide variety of colors. I used to use it primarily for antique picture/painting frame restoration since it has a nice range of golds.
keith zimmerman, Normal, IL
>I really like these variations Jamie. They give a lot of food for thought for different applications of color to a piece. I've been thinking about something like this. It is great to see it in application and to know that it is possible and looks good.
Thanks for sharing.
keithz
Keith Tompkins
Keith Tompkins
>Nice work Jamie! Just curious...how long does it take you to turn a finial, on average?
Re: Keith- actual turning time is maybe.....
JamieD
>...10 min. but you know that all the other parts of the process add much more to that total.
Jamie, these look terrific.............
Ruth Niles
>They look like an art display just the way they are! Very attractive, gives me inspiration.
