OT - Electrical Help, Please
Scott Hurley in N VA
>I just had a 220 line put in for my 1.5 horse dust collector. The motor can be rewired for 220, and the instructions are fairly clear on rewiring in the switch box. However, the last instruction says to "put a 220 plug on the wire". I know that 220 is 2 hots and a neutral, but the electrician put in cable with 4 conductors - 2 hots, a neutral, and ground. I understand about connecting the 2 hots and neutral, but what do I do with the extra ground wire? I'm guessing it would be terminated at the wall box, but not make it to the machine. Can anyone verify that?
Thanks in advance.
Scott
Re: OT - Electrical Help, Please
Bill Turpin in WNC mountains
>Your DC needs two hots and a ground. Since your question shows that you are very limited in your electrical knowledge, I suggest that you call your electrician back to finish the job!
Walter Ahlgrim
>I would think you want to use the 2 hots and the ground.
Walta
Gil Jones...GA
>You only need two hots, and one ground for the 220-volt device.
If you also have a 120-volt circuit wired from the device, such as a light, this is where the neutral comes into play as a return leg for the 120-volt circuit.
GalenV in Iowa
>Better ask the electrician that run in the line.
When I purchased an electric dryer to put in my apartment the installer said the socket and plug to the dryer had to be four wire to meet the current code. Any 230 single phase device. The ground is a dedicated ground to the machine. It has to be wired to the right pin in the socket to carry it through to the machine. The plug pigtail wire to the machine had the green grounded to it.
Galen
>The electrician is coming back for some additional work in a few days, so I check with him then.
Thanks for the quick responses.
Scott
>Scott I'm a definitely hot an electrician but tried to read up on the need of a ground when I ran my 220 line to the shop. I can't remember all the details now so I won't even try to quote them. If I remember correctly it depends on where the box is related to the main box and if they ran a ground from there. It's a safety thing in case of a malfunction in the circuit. In some cases the ground was needed and in some it was actually dangerous. Definitely ask the electrician.
Tony - Memphis
>Now I'm confused. I understand that the ground is required for dryers and such, I thought that most things needed two hots and a neutral, not two hots and a ground? I just wired my TS and it is a three wire with two hots and a neutral - no ground.
Tony (mechanical, NOT electrical engineer!)
>Everything needs a ground unless it is double insulated, ie two wire 120V cords as on portable power tools. 220V tools or appliances do not need a neutral unless they use a 120V control circuit. They do need a ground with the two hots. Dryers and stoves used to be 3-wire (2 hots and ground), but they have been changed to 4-wire (2 hots, neutral, and ground) A lot of this confusion is caused by foreign wire color codes. Lots of European (and electronic) cords are brown, blue, and green/yellow. Which one is the neutral there? Some New Zealand cords use pink and orange. Some mainland Chinese use black as the neutral. If you are not positive of your assumptions and can't check with a proper meter, PLEASE call a competent electrician!
Tony - Memphis
>I guess I was confused thinking that things used to be two hots and a neutral instead of a ground. Thanks. My first experience with this was when we moved form an "old" house to a new house and I had to replace the dryer pigtail. For my tablesaw outlet in the shop, I wired up the outlet and made an extension cord, but I called a pro after I discovered that the two open breaker slots in my panel were actually dummies. At first sight, they were going to replace the guts, but then he decided he could swap some full size for some half size breakers and make room. It worked out good. It is full now though - no more new circuits. Only cost me $120 and he double checked my wiring job which made me feel better. I was just talking to one the EE's here at the office and her reminded me that technically, you don't need a neutral with 220 - I had forgotten that. The older I get, the harder it is to remember what I know/knew!
Tony
Lan Brady
>Bill,
Great advise, quoting Sheriff Andy Taylor "Call the Man!"
I ran the 220 line for my lathe. I wish I could brag about that but it required 6 calls to my brother and 3 trips to Lowes.
Everything I had read and discussed with my brother made since. I was able to understand it all except installing the breaker.
It would not fit, util the guy at Lowes questioned the location in the box. Seems, the double throw breaker must have the 2 legs in a seperate section of the box. That information was second nature to the experienced person but to a complete novice, it was a show stopper.
Again, you give great advice, "Call the Man!"
Lan
GaryC
>Without a ground you have a very dangerous situation!!!!!!
I would unplug your TS until you can get it fixed.
arkie
>Grounds and neutrals serve different purposes. Understanding those differences requires a more thorough knowledge of wiring than "hot and neutral" or "black, white, and green."
Your electrician is coming back - have him take care of this and sleep soundly at night.
Jesper, Denmark
Re: OT PLEASE BE SAFE........
Jesper, Denmark
>There are lots of confusing statements in this thread.
The only wire color that has a real meaning is the ground - it is green/yellow everywhere, USA, EU and the rest of the world.
All the other colors are used differently in different places and by different electricians in the same palce!!!
In the US electrical system, 120 Volt is one hot and one neutral. 220 Volt single phase is two hots. It should NEVER be connected as two hots and a neutral, unless there also is a 120 volt lamp or some other 120 volt rwequirement on the machine. In that case it really should have 4 wires, the last being the ground.
Do not connect the ground on the machine to neutral. The neutral can well have some voltage on it, so if you connect the machine grounding to neutral, you will end up with a voltage on the machine surfaces - dangerous.
Dick Hines
Dick Hines
>I have never had any trouble with wireing until I decided to put electric base board units in the atic of my garage. I was going by the directions, like a good guy, until I go to where I was to hook up the 220. W to W Blk to Blk and ground to ground. Well when I looked at the unit it sure looked like I was goin to have obne big bang if I did it that way. So being the stupid guy when it come to 220 I talked to my wireing expert. He said to follow the driections.
Lesson learned. If you are not sure ask some one who does know. Power can cause a big problem if care is taken.
>Jesper: Green/yellow is ground in EU and sometimes in USA. However green ONLY has been the standard for ground in the USA for decades.
No No No...
Tony - Memphis
>My wiring is 100% correct....I was confused when I was reading the posts the other day. Thanks for the concern though. I'm not real smart, but I'm smart enough to know what I don't know! I did lots of research (books and internet) before I wired it and it has been over a year and a half I guess, so I just forgot and got my neutral and my ground confused.
Tony
Tony, You said......
>"I'm not real smart, but I'm smart enough to know what I don't know!"
That makes you pretty smart. We'd all be better off if we were "smart enough to know what I don't know". And smart enoguh to get good help.
