REAL MILK PAINT
Stuck Live Center
Stuck Live Center
Stuck Live Center
Doc Green
>Last night, I used the live center that came with my Jet mini in the tailstock of my PM 3520. When I went to remove it, it wouldn't eject.
OK, no problem. Inserted a knockout bar through the tailstock ram and gave it a tap or two. On about the third tap, the end cap of the live center came off the bearing, leaving the bearing still seated firmly on the Morse taper. Circumcision came to mind.
Looked through the bore of the tailstock and discovered that the MT of the live center is bored out to exactly the same diameter as the bore of the tailstock. A knockout bar is/was useless. There is nothing for it to knock against.
Talked ugly for a few minutes. Was tempted to pry against the bearing, but I didn't. Didn't really want to tear anything up.
Then I remembered that vibration will tend to loosen a MT if you install one in the headstock spindle - which is why you must use a drawbar to hold it in. Figured I needed some vibration.
Applied a big screwdriver to the side of the MT, and whacked it pretty good, first on one side, then the other, with no visible effect. So I whacked it some more. And more. And more.
With my frustration level rapidly rising to the "bust it to hell" level, I decided to pry against the bearing and let come what may. So I put a little pressure on it, and ...it popped right out and fell into the shavings underneath the lathe. Thank goodness.
An earlier attempt at prying with "a little pressure" had no effect, so the vibration apparently did indeed loosen it so that it would pop out.
Inspection revealed that the MT for the Jet mini is about 1/4" shorter than the MT's I use with the PM, which is why the ejector wouldn't work.
Conclusion: All Morse taper fixtures are not the same and you should give it a bit of thought before you mix and match. ~Doc
Re: Stuck Live Center
Jeff Willaford
>Sounds like you had quite a workout for the evening. Glad you got it out without a fire wrench.
Scott Hurley in N VA
>What our woodturning club (CAW)does with all the Jet mini live centers is jam a little piece of wood in the end of the live center, and shape it to to be an extension of the taper. The wood needs to stick out about 3/8" to 1/2". After that, they back out very easily. Otherwise, as you just found out, you can't get them out of other lathes.
Scott
>Anytime you have a live center that won't eject simply put something between the tailstock body and the live center body that will still leave you some retraction room for the quill. Then crank the quill back and it will push against the live center and pop it out.
It's very similar to using a U shaped jig designed to pop some of the tapers out of drill chucks. Most of the time I just use my skew. Lay it between the bearing and the tailstock body and crank the quill in.
Dick Hines
Dick Hines
>I think the live center for the Mini Jet is shorter than the one for the PM. When you crancked back to get the live center out there was nothing for the quill to push against.
I have one that is supposed to be a MT 2 but it goes in so far that it will not spend. I cut a very thin piece of falshing and wraped it around the MT and that works OK.
Scott Crumpton
>I was once in your situation, but at the other end of the lathe. Now whenever I use a MT drive center, I thread a nut on the spindle first. Then if the MT refuses to release, I drop a "U" cut washer over the drive center and crank the nut out. Works every time. Another advantage of this method is that it protects the threads from accidents.
