stabilizing pen blanks
Gary Evans--Tallassee TN
>Hi all,
I am putting together a rig for vacuum stabilizing pen and knife handle blanks. I'm having difficulty finding the proper preservative to use. I have been told by a longtime knife maker that the professionals use a preservative that is commonly used in museums. It comes in a powder. I'm not even sure what it mixes with. So far I haven't had much luck with google in trying to find a source.
Just wondering if anyone here has more knowledge of blank stabilization than I. Any info would be greatly appreciated.
Thanks,
Gary
Re: stabilizing pen blanks
Ken Oakley-Sunny St. Cloud,Fla
>You might want to post this question on the International Association of Penturners website. Lot of smart people there also
CGelnett
>I have never tried it but here is a link.
http://www.northcoastknives.com/northcoast_knives_tutorials_hints_tips3.htm
>Thank you Ken,
I wasn't aware of that group. I'll check them out.
Gary
>Thanks for the link.
I've thought about the Minwax wood hardener, but I would like to find something a little less pricey that would work the same way if I can. That does look like a pretty safe way to heat up the stabilizer and the blanks.
Gary
russ faifield
>The most common do-it-yourself stabilizing is done with either acrylic (Plexiglass) melted in a solution of acetone or polyester (fiberglass) resins.
Stuart Johnson
>You might want to take a look at Nelsonite. Pool cue makers use it.
Dick Coers
>If you want less costly than Minwax, better switch to acrylic blanks. The real stuff for stabilizing takes a high vacuum to fill the wood cells with polymer, then a high pressure set in an autoclave. Now we're talking money!!!
knife handle blanks?
>Gary, are you getting into making knives or selling knife handle blanks? When I make wands I usually trim with the bandsaw to save time turning the shafts and end up with a bunch of relatively thin slices about 1"x6". I gave a box of them to a knifemaker once and he was excited, perhaps because it included a lot of figured exotics. (His handles were incredibly boring!) What size of blanks are needed for handles? I suspect it varies widely depending on the knife but is there a "standard size" a buyer expects?
Also, I recently got three large english walnut slabs with a lot of figure. I was told they came from a veneer company at least 20 years ago which couldn't use them because of a big hole in the middle of the tree. I'm going to cut most up for boxes and small bowls but there may be some wonderful wood there for knife handles and such.
If you are getting in to selling wood again, you might want to help me harvest some oak burl. One big oak snapped in two in a storm leaving about 25' of trunk with a huge "buttress" at the base. The last time I cut into one of these it was full of burl.
Re: knife handle blanks?
>Hi John,
I sold a couple hundred knife scale sets to a guy over in NC a year or two ago. He is the one who gave me the info on the museum preservative. I have a bunch of pen blanks that would benefit from stabilization, which is why I'm taking a look at it now.
When do you want to get together and cut up that oak?
Gary
>So do you know what size a knife handle blank should be?
>Hi John,
It seems that nothing brings me much more pleasure than sawing pretty wood in to smaller pieces so I've sold a little wood lately.
It's been awhile since I sold those knife handle blanks. Let me go down to the store tomorrow and measure what I have.
I think I was cutting the scales 1/2"x1 1/2"x5", but I could be off a little in any of the dimensions. I think the full handle blocks were maybe 1"x1 1/2"x5". All the scales I sold were book matched and I cut the full blocks to get the best figure on the wide side.
I'd definitely like to check out the oak stump with you and I just started cutting up a bunch of apple and hackberry if you need some.
Let me know when you want to work on it.
Gary
