>Since I am only finishing one bowl or turned box at a time I normally use a spray can. Less clean up and ready to go right off the shelf, but I keep having problems lately with the nozzle plugging up. I normally turn the can upside down for a few seconds and even wipe off any drips on the front of the nozzle. This has worked for me the past several years but lately the nozzle still gets partially plugged. The nozzle is plugged just enough that when I start to spray my project I get a stream of finish.
I have tried taking the nozzle off and soaking it but that does not work very well.
Forgive the obvious, but be sure you spray upside down long enough that the liquid spray stops and the nozzle is just passing gas. (my, but that sounds odd) This doesn't work with some cans I have that spray in any position!
You can also remove the nozzle before storage and blow compressed air through it. I've had good luck with cleaning nozzles by soaking in solvent then reaming with a very fine wire. I've also replaced problem nozzles with those pulled out of empty paint cans.
>I will occasionally put the nozzles in a baby food jar with some mineral spirits and let them sit. I have that problem with my spray adhesive and people at work never turn them upside down so the nozzles are always clogged. It usually works but not every time.
>That would be nice. Last year I sent email to Minwax and asked them if they sold the nozzle separately and the answer was no. I tried talking them into it but the answer was still no.
>If I remember correctly, I once bought some replacement nozzles for spray cans from American Science & Surplus (www.sciplus.com). I just checked and they don't have any in stock. This company is a good source for all sorts of stuff, some useful and others not - some quite inexpensive and others not.
I still have some packets of replacement nozzles in my shop. The company is Workshop Timesavers Inc. P.O. Box 68037 Rochester NY 14618
Write them a letter and see if they still sell them. Good luck.
>The best place to get a very small diameter, very stiff wire is to pull one out of a steel brush. I do this all the time for cleaning motorcycle carburetor jets.
Mineral spirits won't touch built-up lacquer deposits - you must use lacquer thinner. I also have tried the "thin-wire ream-out" technique and it works about half the time, although the atomization seems to never be as good as the 'original' spray.
Once polymerized, polyurethane will be difficult to dissolve with any thinner; you could try lacquer thinner or even acetone....some solvents might damage the nozzle's plastic, however...
I also do what John does, and "borrow" working nozzles from other cans. I use a lot of Deft spray lacquer cans, and whenever one is finished, I save the nozzle for future use before I discard the empty can (I now have a small jar full of extra nozzles!).
I have found that some brands of spray lacquer clog the nozzles more than others - i.e. both Behlen spray lacquers [pre-cat and nitrocellulose] tend to clog the nozzles easily, despite careful inversion spraying and blow-out cleaning - I don't use them any more. Watco spray lacquer is a bit better for not clogging, but I don't like the finishing characteristics of the lacquer (tends to blush easily). I've been happy with Deft lacquer, and use it almost exclusively when I do a spray finish.
>I do what you do, turn the can upside down and spray to clear the nozzle. Works for me. If you have to resort to soaking a clogged nozzle, make sure the solvent is appropriate to what is in the spray can. Lacquer thinner for lacquers and mineral spirits for polyurethanes.
