peculiar bubbling areas on black spalted maple
Andy Barss
>I was reorganizing a shed yesterday, and came across a large block of spalted bigleaf maple I bought three or so years ago from a guy in Washington State (I live in Arizona). One side, and two endgrain ends, of the block (it's big, 22x22x7) had a strange appearance. When I looked at them more closely, the areas of black spalting (in this piece, as well as a couple others, there are contiguous patches of black, rather than the
nice spidery lines we all love) had "bubbled" -- there were blisters sticking up off the surface 1/8" to 1/4" high, anywhere from 1/4" to 1" across. They're hard -- I thought initially they might be termite areas, where they eat all the wood under the surface leaving a shell a few fibers thick.
When I cut through the bubbles/blisters with a knife, what appeared inside was white, and although it was hard, it crumbled easily. It was like coarse-grained, slightly dirty, chalk.
What is this? Is there any concern about this being a nasty form of spalting I should avoid, or is it safe to turn?
Or is it something which might infect the other wood in my shop if I bring it in?
Thanks,
Andy Barss
Re: peculiar bubbling areas on black spalted maple
Brad Vietje
Brad Vietje
>Andy,
Well this may be one of those times when a photo will be worth a gajillion words... You might be looking at small fungi that started creating a fruiting structure, based on the moisture in the wood, then dried up in the AZ air (?)
We don't have Big Leaf Maple around here, but at least 6 - 7 other Maple varieties, and left hanging around, they will spalt. I've seen small "blooms" of hard, little rounded fungi coming out of dead wood -- could this be it?
I'll attempt to attach a web pic of a hard little Coral Spot Fungus growing on a tree -- is this similar(?)
Safe spinning,
Brad Vietje
Newbury, VT
