Coffee Grinds Filler
jwoodwright
>Fresh Coffee from the can, or are they dried grounds after brewing? Also, what is the adhesive of choice?
I tried researching this and hit a big fat zero. I appreciate your help.
Re: Coffee Grinds Filler
>When I fill voids, it depends on how large the void. If it is a large void, I'll use epoxy and a suitable filler. If it is a small void, I'll pack it full of a suitable filler and use CA glue. As far as coffee grounds, I don't drink coffee, so I just take some from the freezer and use it. I'm usually trying to fill a knot hole or pitch pocket.
I thought I was the only human who doesn't
>drink coffee. I do keep some at the house so when someone comes over they can have their fix. I generally use sawdust, I keep a variety of woods like ebony and such. I have tried coffee, just straight out of the can and it looks good to patch knot areas.
Some folks use instant coffee. Finer grit.
adrien
Brad Vietje
I wouldn't waste perfectly good coffee grounds...
Brad Vietje
>... I'd make a cup of coffee with it first!
I've used used grounds a few times, but you want them to sit on top of the compost bucket a bit to make sure they're not too wet. Water content will set the CA, so make sure there's not too much moisture, or it will foam at the surface and not get in deep.
Or you could use unused grounds, which are drier, I suppose. I just hate to waste the stuff ;-D
Safe spinning,
Brad Vietje
Newbury, VT
Re: I wouldn't waste perfectly good coffee grounds
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>Dried, but used, coffee grounds.
However, I more often use sawdust from the bandsaw, or brass filings from the Home Depot key machine. I keep a bunch of labeled bags of such materials so I can match needed colors.
Pack the material into the void or crack with a dental pick, then soak with thin CA glue, then you can repeat, etc.
------WebKitFormBoundarygO+DtleCSxS01GQ4
------WebKitFormBoundarypM+IwnkH0ZoRCpIN
Doc Green
>I use "fresh from the can" with 5-minute epoxy. Mix the epoxy then add the coffee grounds to get a "stiff" mixture. Used grounds give a finer texture.
Be aware, after you add the coffee, you will only have a couple of minutes to work the mix with 5-minute epoxy. For best results, let it cure for a day at least before trying to sand it, but you can turn it after about 30 minutes. After it has cured for perhaps 10 minutes, it carves nicely with a sharp knife.
Good Luck, ~Doc
Re: I thought I was the only human who doesn't
GalenV in Iowa
>Not being a coffee drinker myself and too cheap to go buy it I used ground cinnamon spice mixed in the epoxy to fill my first bowl that had a void. Why? Because I had three tins of cinnamon.
Guess being new to this you can use anything!
Galen
Carol Reed - Strawberry, AZ
>No John, you're not. I don't drink coffee either. I used to keep some in the freezer for guests, but now if they want coffee they have to bring it!
Great Ideas!
jwoodwright
>Thank you all! Nature "hid" a defect.... I found it! I've tried sawdust and yellow glue. Someone emailed me the idea of using an old coffee grinder to make the sawdust finer... Time to check out Salvation Army Thrift Store...
Steve Kubien
Don't worry John...
Steve Kubien
>...I don't drink it either. I take mine intravenously.
Barbara Gill------WebKitFormBoundarypTwA+e87REJF0d
>I dry the used coffee grounds. Usually I use either CA glue or West System epoxy.
Ken Vaughan
Ken Vaughan
>Likewise used coffee -- but I have had coffee grains (pieces of regular grind) come out of the epoxy matrix leaving small holes -- so run it back through the coffee mill and make it more fine like expresso then use as filler. CA works but can become brittle with time and seems to chip a bit. West Systems and System 3 seem to work nicely.
Have long thought that having a buddy at the expresso stand would be perfect to get the fine grind used grounds -
If I lived up there I would be drinking coffee
Espressor grounds
J Byron
>i get espresso grounds from my local coffeehouse. espresso are ground very fine so they compress better than courser grounds.
lay out the wet grounds on a wire mess until dry --
ca glue really loves 'em
Re: Espressor grounds
Jim Rutten
>To quote Mr. Lucas "I do keep some at the house so when someone comes over they can have their fix. I generally use sawdust."
Just wondered if that made your coffee kind of gritty?
Re: Great Ideas!
>These are great Ideas. One thing nobody mentioned is you might want to practice first. I my experience, coffee grounds turn extremely dark once mixed with epoxy or soaked with CA. Walnut sawdust also gets darker than the surrounding wood, even if it came from the same board. Might want to mix the walnut half and half with cherry. You can also get really artistic and create knots with lighter "wood" around them. Play with it a little first, before jumping on your repair. (I can't believe I said that, I usually just take a whack at it.)
Re:And Jim, it has a nice oaky flavor!
JamieD
A slight variation
Jerry Hall
>on all the good ideas above is to drench the crack and or void with lacquer sealer, and then while wet press in Sanka which crunches in nicely and the sealer temporarily holds it in, then drip thin CA on the crack, sopping up over-runs. Then in a few minutes you can turn away or sand off the mess. I think the lacquer acts a little bit like an accelerator. When I have time I will tell you how to remove the blank from your fingers.
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Another slight variation... I get the coffee grounds from the local expresso stand. The girls will put them in a cup for me when I ask. A coffee cup filled will dry quickly and then it can be used for a long time. The expresso grounds are finer than regular coffee and free.
Skip
sawdust mixed with cement for wood models
bob davis5098
>as an ex model builder i use testors cement a lot instead of epoxy
