>Backed in under the hoist. Picked the thing up. Set it on sawhorses. Unwrapped it. Picked up each leg and set aside. Hoist held lathe in the air while I bolted the legs on.
Dave, thanks for the offer to help set-up but when you get here we ought to be able to play instead!
Still have to clean out the turning shack and get it in there. Hoist will do the heavy lifting again. Then run the 220 circuit, clean it up and away we go!
>Congratulations, Carol. I know you will enjoy it! You say you have to get it in the turning shcak...where is it now? Looks like it is pretty comfortable where it is. ;)
>The door to the turning shack is just behind it. Right now it is standing where I park the car. It IS a carport! And gotta keep the wheels out of the Arizona sun.
>Congratulations on your new lathe. You'll have many hours of satisfaction working with your new toy. I have a hoist in my shop also and found it very helpful in assembling my new lathe when it arrived 1 1/2 years ago. Enjoy!
>Didn't you set up a mobile workshop at some point? Whatever happened to that? I know your Jet wouldn't have fit in there, but I just happened to think about it.
Before I started turning with my 1642, I replaced the stock short cord with one about 15' long so I won't have to use an extension cord. Might want to look into that before you get too far into playing with it.
>Good for you Carol. Just read on another forum that Jet is discontinuing the 2 hp model, so you may have got one of the last. Apparently most sales were the 1.5 hp, 110V lathe. Pls. be careful moving it.
>Carol, that lathe is snow white. How can you expect to become a turner with a lathe that white.
I am sure you can find some sawdust around there somewhere. Get a handful and rub it on that lathe so that it understands its purpose. Get it used to smelling wood chips. Make that baby behave.
Right now it is sitting there looking pretty. The only thing that is supposed to be sitting there looking pretty is you or something you made....
If you haven't already read the thread at the link below, you might consider doing a few of the "prep" procedures before you begin playing on your new machine!
Took a break in the service prep this afternoon and got the electrical plug installed. Also put up some of the conduit for the circuit - enough to know what other items I need to finish that job.
Then back to worship prep. The lathe has to wait until Monday now.
