Turning non-ferrous metals?
>I need to "trim" about 1/8" of thickness off of some brass fitments. I don't have a metal lathe, though I do have my Jet.
Any advice as to which tools to use and how to proceed?
TIA
TIA
Re: Turning non-ferrous metals?
>I use any of my tools. I find bevel rubbing and cutting tools to be the best but it sort of depends on the metal and whether it has been work hardened. Sometimes a scraper is simply better. Try one, if it seems to be tearing out try another.
To cut tubing or the ends off of hollow pieces I turn a wooden dowel to fit inside. This supports the metal and keeps it from deforming and vibrating. You get a cleaner cut. My favorite tool for turning metal is the Thompson detail gouge. I use it to cut through tubing by pointing the flute sideways and taking what amounts to a V cut. Parting tools tend to chatter although I have thin tool that works fairly well if the metal is soft. The toe of a skew works well but of course it dulls the hell out of it.
Brass is supposed to be...
Steve Kubien
>...easier than aluminum and when I made this pen I used a gouge and a skew. No problem.
Chuck Engstrom
>I am no machine shop wizard but I think you will find that brass responds better to a scraping technique than a cutting technique. I've had to shape some brass finials and did all of it with woodturning scrapers, well sharpened, brought up to the metal at 90 degress.
Good luck with it and Happy New Year!
Chuck
adrien
>It might be a good idea to put plastic sheeting down under the piece so that the metal shavings don't get mixed in with your wooden ones. I sometimes use the wood shavings to polish a piece and the metal stuff could create problems.
