Hey Barry Irby...
Carole Valentine
>What ever happened with the coring system fiasco? Did your "friend" ever replace your blades that he ground into oblivion? I think about that everytime I hone mine! LOL
Hey Barry Irby...
Carole Valentine
Re: Hey Barry Irby...
>No, he has not replaced them, but I have not seen him or confronted him about it. I am not confrontational and would rather let it go than bust him with it. this is a person I have known for a long time, but only slightly. He was in a Garden Club I was in for 20 years, but only saw him once or twice a year. Then he showed up at the turning club. It was my mistake loanign the system to him. Another lesson in what happens when you loan things.
I sent them to Mike Hunter and he replaced the cutters with some of the carbide ones he uses. They work much better than they did originally. I have not used them much, but this is a significant improvement. I would recommend the upgrade if you have any doubt.
The cutters Mike installed are diamond shaped and reversible. So you can use one end until it dulls and then reverse it. I got him to send me a couple of spares and a couple of the screws extra also. I figured I needed a screw or two to drop.
Other than being backed into the expense of this durring these tough times, I am relly happy with the cutters now. I need to install some sort of laser on them now.
Tom Vensel
>A friend of mine has a poster in his shop that says "If you loan a friend $20 and never see him again it usually works out good for both of you" . Tom in S/E Ohio
>You are correct. $20 would have been a heck of a bargain, this was closer to $200. I need the attitude I use when lending money. If you borrow money from me I think about the amount and if you never paid me back and that would not affect the friendship, I will loan it. I loaned a friend $7,000 once. I was surprised and I have to admit pleased, when he returned it. Times are tough right now, I wish he still owed me and was trying to repay it now.
Carole Valentine
>Barry, my cutters work just fine so I see no need to do anything to them other than hone them...nice ribbons coming out of the kerf (at least until I do something stupid, and I am at the bottom of the learning curve here so I do that quite often.) Mine are the newer blades that come with the Mark 8 System and they have a diamond shaped cutter tip.
I have one carbide tipped tool and I found the carbide to be quite brittle and chippy.
If it Ain't broken, don't fix it....
>If its working for you, leave it alone. Don't spend the bucks. Perhaps you could spend the savings on a Hunter tool. I would like to have one myself.
