another use for Beal buffer
>I don't know if anyone has posted about this before, but the Beal buffing wheels are great for repairing scratched CDs and DVDs. I used to repair by hand with polishing compound but this is a lot quicker.
I use both the tripoli and white diamond wheels and clean as needed with DNA on a soft cloth. So far, this has worked every time, even on some disks with some horribly deep scratches. If the scratches are severe, I sand up to the finest grit I have before buffing. (Note that most of the thickness of a disk is in the clear plastic on the data access side so you can remove quite deep scratches. The label side, otoh, is relatively fragile.)
I rotate the disk around the point of contact with the wheel while buffing my way around the disk so each area gets overlapping and crossing abrasion. This takes about 10 minutes or so, depending on the level of damage. Don't fret about the cloud of very tiny scratches left by the white diamond compound - the laser can "see" right through them. (The plastic surface is a long relative distance from the metal data layer and considerably "out of focus" to the laser optics.)
I've heard there are polishing machines in some video stores but this has to be more fun. It is best done wearing a WoodCentral shirt.
Be careful to hold the disk tightly - I suspect slinging it across the room wouldn't help the data.
