Dang! Did you Canucks lose something?
Carole Valentine
>Like a whole bunch of Canadian cold and wind? Would you please come get it? It's not at all welcome here in Virginia! ;)
Re: Dang! Did you Canucks lose something?
Steve Kubien
Steve Kubien
>Well, we've got some cold here today. I cannot tell you how much but I will say, I'm not going outside unless I have to. Mind you, it was a mild, green Christmas here.
ThomD
>I thought this was going to be a Oneway, Robust,Serious lathe thread...
Carol Reed - Strawberry, AZ
>They lost it a whole further south than Virginia! Means they lost a lot of it!
The geese that leave Canada for teh winter are finding their ponds frozen in Arizona!
Bob Chipchuck >>> Winnipeg
>What are you complaining about... it was -40C here the other week.... big deal eh!
Bob
Mike Stafford
Just proves border is way too porous...LOL
Mike Stafford
Ken Oakley-Sunny St. Cloud,Fla
>Florida either- 39 degrees here this AM-- That's Farenheit---
Brad Vietje
I'd be happy to trade those for -10 ...
Brad Vietje
>... with wind chills more like -25...
And to make matters even more fun, I have to work outside tomorrow! High temp may reach 16 or so. Should be fun.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Nice weather for turning softer woods.
Brad Vietje
>One advantage we Northerners have is a really really big walk-out freezer. This week, folks down South can see what they've been missing. BTW: -40 is -40 on both scales -- also known colloquially as "PFC" :o)
Want to turn some Basswood, or Aspen? How about getting a clean cut in Butternut or Sumac? Just toss the green logs outside, let them freeze solid, and no problem-o, they will cut much better when frozen.
Of course, you may not like the experience much, but you'll develop a really close relationship with the woodstove!
Safe spinning,
Brad Vietje
Newbury, VT
Carole, sent from Alaska via Canada with love...
jwoodwright
Thanks a bunch, JW ;)
Carole Valentine
Keith Tompkins
Re: Nice weather for turning softer woods.
Keith Tompkins
>Brad, I drove to Ottawa last year for a demo...-27 degrees in upstate New York when I hit a lake-effect blizzard off Lake Ontario. I followed a path made by a tractor-trailer while my wife scraped the INSIDE of the windshield so I could see. Cars were everywhere, completely covered with snow. It's going below zero tonight.
I agree Carole- need weather from Florida
And wouldn't you know it...
Carole Valentine
>I finally have a nice warm shop to play in and now my lathe has decided that it will not spin anything heavier than 5 or 6 pounds without roaring at me then stopping! Looks like I won't be practicing with my coring system for a while. :((
Dick Hines
Re: And wouldn't you know it...
Dick Hines
>Carole, I am glad you shop is warm. I spent all day in mine with the doors wide open. The onlu heat I had was from the sun shineing thoswe doors. I have about 1-2 days and I should have the shop all closed in. Then it will take me a week to get everytning back where it belongs.
It has been 2 weeks since I have turned anything. The lathe is behind a pile of 2x4s and chip board.
Carole Valentine
>At least your lathe works. Warm shop doesn't do me much good when I can't do what I want to do because the stupid lathe has decided to check out.
Re: Carole- these are the times when ....
Jamie Donaldson
>...you need that 2nd lathe! Been too cold to turn in my shop here in KY for about the last week, so I spent the afternoon cutting firewood for when it turns even colder after new year day.
Carole Valentine
>Jamie, I have a second lathe, but it's just a Jet Mini. I need the big lathe right now. :((
Jorge Castaneda~Downeast Maine
>Carole,
Have you tried blowing compressed air very carefully? a lot of electrical problems are due to dust, others are due to moisture, try spraying DW40 (water deterrent 40 as well.
Just a thought, hope is not something more serious.
Jorge)
Carole Valentine
>Thanks, Jorge. The growling under load makes me think it might be bearings. But then I am not sure if that would make the lathe do it's stop thing like it does when you get a severe catch. It certainly shouldn't do that with normal to light cutting and no catch. It's fine with small pieces and light loads.
>Carol, I have a DVR older than yours. You are supposed to blow them out occasionally. There is a sensor that gets dusty. Does not make much sense from your description, but give it a try. Easy and you can do it yourself. Doesn't cost anything and doesn't hurt anything at worst. Besides that, its the only thing I know to do. A one trick pony needs to use the trick occasionally.
Carole Valentine
>Thanks, Barry. On your and Jorge's advice, I will try that today unless I hear from Tim first. Do you just take the back plate off, turn the pressure down on the air hose and have at it? Don't want to make things any worse, since I can still turn smaller, lighter stuff right now!
Mac Ray
>Might be a good time to consider a white one.................
>It has been a while and I'm thinking its time for me to do it again.
As I recall, you are right. I believe the hand wheel has to come off to remove the back plate entirely, but you can probably get by just removing the screws and shifting the cover enough to get the nozzle in there. I think there are some slots in the head stock (inlets/ports) and you can blow through those as well. I would unplug the lathe and be careful. The circuit board is in plane site with the panel off. I don't think you could hurt it with even fairly high pressure air, but you wouldn't want to hit it with the nozzle. Might break or short something. Parts of the board might retain enough charge to do some damage even with it unplugged. (I don't know that, electronics are not my thing, but being careful would be better than poking it with the nozzle.) I was surprised at how much dust I blew out of mine. Probably not as much as it looked like, but an impressive little cloud.
Mine has cap screws on the plate. Always thought it was a poor choice. Look like something that would take some skin off if you were s little careless with the hand wheel or bar.
Re: Maybe a black or gray one!
Jamie Donaldson
