On the subject of Bandsaw blades
Steven Antonucci
steve antonucci
>The other day, I had nothing better to do than to hand sharpen my bandsaw blade. At 142" and 3 TPI, I knew it would take a while, but I figured it wasn't as long as driving to Woodcraft in Allentown (3 hrs round trip) and it just might work.
I have a small conical diamond hone that I bought at the local BORG. It folds out of a flat handle which is convenient for keeping it flat on the table. Diamonds cut very quickly, and I used about 1/2" of motion with 2-3 back and forths per tooth in the gullet. About 30 minutes later, I was done.
Have to say that it was 30 minutes well spent, as the blade cuts very well now, and it doesn't wander at all. I was afraid that using my Dremel might change the shape too much, but hand held is very controlable and diamond is very efficient.
Try it and save $28 or so...
S
Re: On the subject of Bandsaw blades
>Steve, could you 'plain that a little better? I have tried it with the Dremel but have not been very happy. I was sharpening the "top" of the tooth. Sounds to me like you were doing the gullet side.
I have a couple of diamond hones mostly made for fishing knives and hooks etc. One is a cylinder and the other is a long thin cone or tapered rod. I can sharpen a blade in about twenty minutes with the Dremel, but not all that well, so its not worth it.
>Barry I get my blades from a local supplier for $6 so I don't sharpen them often. Better to just toss them. However I usually need a new blade on a weekend when he isn't open so I take a few minutes to sharpen.
I rotate the blade by hand, backwards, and hold a flat diamond hone against the teeth. Then I take a Dremel with a cone shaped grinding wheel and grind the gullet. Takes about 15 to 20 minutes however it does ruin the grinding wheel after just a few sharpenings and they cost about $4 to replace so I may try Steve's diamond hone since I already have one.
If I used more expensive blades I would probably put more effort into sharpening them carefully but these blades are used solely for roughing green wood so safety is the main factor. You tend to push wood into a dull blade which is not safe.
Steven Antonucci
A picture
steve antonucci
>Here is the little hone that I used. It folds out of the flat black case behind it, which holds it level on the table. The cone tapers, so I just matched the radius to the gullet's radius and I move the hone forward like a file maybe 1/4" or so 2-3X.
The insert is a piece of bamboo flooring. Since I own a lathe, I don't buy inserts anymore, I just turn them out of whatever is laying around.
S
Steven Antonucci
and now, the picture
steve antonucci
Thanks
>I am going to try this. I have a 14 BS with riser, so the blades are 105" and I use 3tpi. I'm like John, they don't cost a lot but they get dull on the weekend. I need to find a better place to buy them, I'm paying about $10 each. So, if I could sharpen one in 20 minutes, that would be about $30 an hour. Actually, better than that, because it takes five or ten minutes to change a blade. And It would suit my frugal cheap packrat nature to not toss a blade. I carry a similar diamond hone in my pocket when I am working on houses. A wonderful thing to sharpen everything that needs sharpening, except my mind.
I like your insert, got to try that too.
And one more question....
>You keep the hone horizontal and at ninety degrees to the blade and stroke straight across and all in the same direction? No changing angles and directions to compensate for the set in the teeth?
Steven Antonucci
You can compensate for set if you want
steve antonucci
>I am extremely right handed, so I sharpened all of the teeth using my right hand, with a slight adjustment every tooth to keep the gullet square to the set. The hone is removing so little material, I didn't bother to "jig" it (s'pose you could?).
I only honed from the tip of the tooth to the back of the round, ot the whole gullet. I also suppose that you could use a flat hone to hit the top of the tooth if you wanted to be super over the top about it...
Steve
(also have the same sensibilities with regards to money and time...)
Re:I use the small round stone bits...
JamieD
>... normally used for sharpening chainsaw blades in my Dremel. They are often sold 3 per pkg. and are very cost effective, and fit the gullet size to the bit diameter. The effort is usually noticeably better cutting, but with a 148" blade on the saw it does take a while, and my hands need a coffee break or 2 during the process!
Re: And one more question....
Jorge Castaneda~Downeast Maine
>Barry,
I mark one toot with a marker and then sharpen every other from the same side, then the other half from the other side, that way you keep the set, it is not exactly square across, there is some "fleam" and "flam" involved, just like in the chain saw, but more subtle. You always sharpen a toot that angles away from you.
Now that I muddied the waters, I retreat... I did not invented the terms, any old booklet on saw sharpening explains the terms.
Jorge
russ faifield
>The problem with the use it 1-time and throw it away is that the 1-time is less than a minute when there is a nail in the wood.
I grind the back side of the tops of the teeth with a Dremel cut-off wheel. I use 2 wheels because they break easilly. It isn't perfect, but it works and it is fast. I can get 4 or 5 sharpenings out of a 1/2" X 3 TPI blade.
All it takes is a light touch, and there is no need to move from side to side to compensate for the set in the teeth. It takes about 5 minutes to sharpen a 105" blade.
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA
>What I'd like to know more about is not so much sharpening band saw blades but repairing a broken one. Sometimes I manage to snap a brand new blade for some stupid reason. I seem to remember something about a little repair kit for welding blades together. Any ideas here?
Steven Antonucci
This plus mine= "new blade"
steve antonucci
>Steven Russell advocates this method. As a woodturner, a lot of what I am cutting is sappy, wet log and all I want it a "pretty good cut". I think sharpening the gullet helps clear the cut a little better, but sharp is sharp.
Steve
Mike Peace
Mike Peace
>I have done what Russ describes after seeing someone do this on a Youtube video. Seems to work ok. For an $18 blade it was well worth the limited effort involved. Not quite as good as a new blade but a major improvement after I had tried to cut a screw by accident.
Re: On the subject of Bandsaw blades *LINK*
>Eliot I would have to dig a little to find it. I think it might have been woodcraft or Craft supplies. I'll go look. You silver solder them with this method. Welding requires specialized equipment. Silver soldering only requires a jig to hold it square and that's what is sold with the kit.
I found one in Lee Valley. check the link.
http://www.leevalley.com/wood/page.aspx?c=2&p=41049&cat=1,41036
The Gullet
Ron Sardo
>The gullet is where the sawdust goes until it exits the wood.
The bigger the wood, the bigger the gullet, the better the cut.
Don Orr
>I use Russ's method and it works well. Just did it the other day and it renewed a dull blade to like new.
>That's the way I sharpen my 3 or 4 tpi bandsaw blades. I often sharpen them 3 or 4 times. I do not sharpen blades with fine teeth.
Michael Stadulis in Southern NJ, near Philadelphia
>Elliott,
Please send me your email address offline and I can forward some info to you some.
Mike
isharpen like russ
bob davis5098
>get several sharpenings. i use diamond one inch cut off wheels from harbor freight.inexpensive
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
>Michael,Thanks for offering, but I don't have your email address. I tried to find it on the profiles, but didn't see your name there.
arthur mc viccar
>Eliot- I use the bandsaw repair kit, which I think came from Woodcraft. I buy bandsaw coil stock from Fastenal, and make my own bandsaw blades. You use silver solder and Mapp gas, and it really is very easy. Extra silver solder can be purchased from any welding supply or from a well stocked college art supply store where they sell jewelry making supplies. And I resharpen my own blades using the Dremel stone made for chainsaws. I usually get 2 sharpenings from a stone and then throw it away. I use a hand held grinder, which operates off the compressor
