>>I haven't had much luck with cocobolo, or the rosewoods
Miles, do you have trouble with cocobolo and the other rosewoods cracking just when you make peppermills or other things as well? Cracking while working or some time later?
I've made some cocobolo mills and lots of boxes and other things and can't remember a single crack. Maybe my cocobolo is drier? For boxes, I usually rough turn then let the blanks sit for a couple of months before turning, maybe that helps. Pepper mills I just made from freshly cut blocks.
If your wood is not as dry or stable, perhaps it would help to drill a hole through the middle and let stabilize before final drilling and shaping, just like a box. (Haven't tried this)
>Have not personally made any peppermills, but I would suspect that drilling the large bore would generate a bit of heat that could cause cracking. Are they cracking as, or immediately after you drill? If so, maybe try slowing down your drilling and drill in short spurts to give the wood and bit a chance to cool down. You might even try a little water spray. I have turned a lot of the rosewoods and ebonys, including Black and White, and have had no problem with cracking.
>It's also helpful to take that large bore in steps, starting maybe around 1/2", then upping to around 7/8, and finally full size. Orientation of the bit in the tail stock sometimes makes a big difference in how well chips will clear and eject. That's in addition to Carol's comments, sharp bits, and low speeds for drilling.
>I thank all those posting a response. I guess I should have been more specific, it is the tops that are craking, not the body. I purchased some of those maxi-cut bits, although they cost a small fortune, they cut like crazy, no heat build up here. With the roto stop morse taper adapter, they are great.
The cracks come on the tops, running against the wood grain, not with it, They usually show a few days after finishing the piece. The only method of finishing I know is to try dry out the wood with laqquer thinner, then immediately apply shellac to the wood. I wipe it off with a rag, it will dry right away. Then if I want a brighter finish, I can buff it.
So what I'm really asking is for some finishing tips. Maybe the woods are to wet, I buy them from Packards or Craft.
>Could the lacquer thinner be drying out the wood too much at the surface and contributing to the cracks? I've never tried that.
For cocobolo I usually also use shellac (in the form of Mylands friction polish) directly after sanding to 600 but without any surface treatment. For larger items like these pepper mills, I apply with the lathe stopped, hand rubbed.
>Quote: The only method of finishing I know is to try dry out the wood with laqquer thinner, then immediately apply shellac to the wood. I wipe it off with a rag, it will dry right away.
If anything, lacquer thinner is only drying the surface of the ebony not the core.
Thick ebony is very difficult to dry, I have 2" thick ebony that at the core is still reads 20% EMC after sitting for years.
>you may be getting heat cracks from sanding, i have had this trouble and it has ruined a few tops for my mills :( i use a power drill and have found you need a light touch and go slow, not had many issues since.
>I have had the same problem here in Texas. I had a 4x4x5 of black and white ebony. I ran it throught the band saw and only cut off 1/8 of an inch on one end to look at the wood. I sat it aside for an afternoon and when I was ready to use it 4 hours later there were tiny little cracks.
At the time it was raining so the humidity was quite high at the time.
>No experience with Black & White Ebony, but I have had a problem with Gaboon Ebony pen blanks cracking. I think it was the heat from drilling the blanks. Three or four blanks cracked while drilling. Another cracked a few weeks after the pen was made, perhaps from the wood contracting around the brass pen tube as it dried out? Of course, Ebony is so dense, it probably takes a lot longer to season than we might expect.
