A55 Smoothing Plane
Cleaned the Stuck chuck.
>I posted down below about my Super Nova chuck being very stiff. I took it completely apart and cleaned everything. Honed some parts and shined up the surfaces. Everything seemed to move freely and very nicely until I put the C ring back in. That stiffened it up considerably. Its much better and acceptable, but still a bit stiff. Does anybody know if that ring is supposed to be "warped" or should it lie in a plane. I couldn't decide if it was bent or made that way. I don't think its making the scroll ring tighter contribute to the accuracy of the chuck. I could take my other one apart and look at that one, but Christmas is coming and there is much to do.
Re: Cleaned the Stuck chuck.
>Barry Did you clean the groove that the ring goes into. It could have some build up that makes it push against the back.
Re: Cleaned the Stuck chuck. *LINK*
GalenV in Iowa
>Don't have that chuck but if this is the manual they refer to a grub screw that controls the chuck action. Trouble shooting step #5. I see it has a fibre washer under it so not metal to metal contact. Might relate to your stiff action?
Looks like the snap ring should be flat.
Not sure if this helps.
Galen
Super Nova manual
>I did clean the groove. I cleaned all the mating surfaces. I think the C ring is pressing the scroll too hard against the underside of the chuck body. I lubed it with powdered graphite.
>I have the older Super Nova, Not the "2" model. Mine uses the old chuck key.
I think the "Circlip" is supposed to be flat, not wavy.
>Maybe the chuck body isn't seated all the way or there is some obstruction keeping it from seating. I doubt that the C ring is directional. Try flipping it over just in case.
Dick Hines
Dick Hines
>Stuck Chuck. Sounds like a rock band.
The c-clip should lay flat in the grove.
Don Evans
>Barry:
That ring is very easy to bend and very difficult to get back in with out warping it out of shape if using regular snap ring pliers. You can take it back out and bend it by hand - back into flat plane, then with careful reinsertion with the correct wording you can get it in there maybe on the third try.
Don
don lewonczyk
>The c ring should be flat,a good hardware or tractor supply should have one in stock. If not flatten out the ring without distorting it and with a forstner drill bit slightly smaller then the ring drill a shallow hole in a piece of hardwood scrap where the ring will stand proud of the wood . On a flat surface and about 120 grit sandpaper take the ring down so the whole piece is shiny,reverse the ring in the hole and repeat. You shouldn't lose much thickness off the ring and in fact it should also relieve some of the tension on the back of the chuck. Good Luck, DonL
Thanks Don, good idea.
>I had not thought about sanding it flat. I was thinking of hammering it, but thought that might distort it in other ways I Polished it a bit with 1500 grit sand paper, basically feeling for burrs.
This chuck was a second I bought on the Internet. When I took it apart I discovered all kinds of little rough places and mill marks on the various pieces. Its as if all the reject parts were assembled into a barely workable chuck. Actually, I don't know that. Maybe the parts on my other chuck (paid the retail on that one) are the same. I may take it apart and look to see. Could be that the internal surfaces are never as polished as I thought. Not much point in it if it does not affect performance. I am trying to decide if the stiffness has any benefit. Does it make the chuck less "sloppy" or just more difficult to open and close? If the scroll ring is tough to turn with out the other parts installed, does that have any effect on performance? As I was typing the it occurred to em that the race the ring in in might be too large in diameter, forcing the ring to turn into a cone rather than lie flat. HMMM?
Re: Thanks Don, good idea.
>All my chucks that I've disassembled were rough inside. Probably doesn't pay to polish. I don't think a tight ring gear would affect the precision or holding power but might eventually cause excessive wear.
Just don't overtighten! That's what nearly destroyed the used chuck I mentioned earlier. It had been so abused the flat shiny metal on the front facee of the chuck body was no longer flat, but distorted near the machined ways. I should have gotten the hint when I looked at the chuck key - the teeth were badly worn. Guy probably used a cheater bar to try to hold pieces too big and heavy for that size chuck.
