segmented bowl bloodwood bleeds
Ed Jones
>Feature ring on segmented bowl is fishook design with bloodwood and maple. Problem is the bloodwood "bleeds" red just like a blood smear on to the maple. There are over 200 pieces of maple and bloodwood in this ring, with the ring 1.5" high. Several attemps to finish -all with blood smears on the maple.
1st try- sanded thru grits to 400- raged on shellac base finish -smears. Thought fine sawdust was the problem- removed finish.
2ND TRY- scrapper used only- no sanding- applied finish same problem. Must be finish that reacts to bloodwood- removed finish.
3rd try- sanded to 400 after removing finish. raged on lacquer dealer- same problem
4th try scraped off finish. With lathe at very slow speed sprayed on mist coats of deft. Much better just slight bleed . The finish must be disolving something from the bloodwood
Anyone have or solved this problem. Thanks for reading this.
