Here is the steady rest I needed wheels for. Turned out okay.
It's made from scrap ply and poplar.
On the lathe in the picture is a chair post I am starting on. I have it to rough diameter and was using a skew on it. The skew has been sharpened (on water stones) and is sharp. Maybe not quite as sharp as my plane irons, but it seems pretty sharp.
When you are using a skew chisel, should the lathe be at a high rpm?
Also, I am getting a, for lack of better description, lumpy feeling on the chair post in some areas. I can't seem to get it really smooth in these areas. What might be causing this? Any ideas?
Lastly, when you are using a skew chisel, only the edge or corner of the chisel should lay on the tool rest, right?
Doesn't really matter but most people are more comfortable with a moderate to high speed. When I demo I will sometimes run the lathe really really slow to show the cut. I can get just as clean of a cut at this slow speed. It is easier for most people to make a smooth controlled cut when using a higher speed. How fast? depends on the spindle size. Pen turner frequently use 3000 rpm or higher. I turn chair legs at around 1800 to 2500 but I turn faster than a lot of people.
A lot of things can cause a lumpy surface. Without seeing it I'm guessing. Sometimes the figure in the wood can cause a lumpy feeling. The summer winter grain can cause the tool to bounce which leaves it lumpy. The most common cause is spindle whip. Your steady rest should help this considerably. Try putting less pressure on the bevel of the skew. This flexes the shaft less.
For planing cuts you should be using the lower 1/3 of the skew edge. Never go above the half way point or you can get a catch. I only use the very tip (toe or heel) when I approach a corner such as turning the flat area into a bead that sticks up. I also use the point when turning beads. I start the cut about 1/4 way up the skew and then rotate the tool so just the point is cutting as I move over the bead to the bottom.
>That lumpy feeling could be from vibration. It it has a spiral pattern around the wood, it is definitely vibration.
If the steady is in the center of the piece you could have a vibration node on either side of the rest. Try moving the rest to a 1/3 location and see if that solves the problem.
Another way to control vibration is to use less, or more, tailstock pressure. That means using a spurcenter to drive the wood. That will allow you to vary the tailstock pressure. Vary lathe speed at the same time. It will make a difference.
Adding a twisting load to the piece will also reduce the vibration in long skinny pieces. Do this with a spur center in the spindle to drive the wood, and use a dead cup center in the tailstock. This adds some friction load and that will help kill vibration. Use some wax to lubricate the cup center. Cup centers are used in the spindle these days as a "safety center" for driving the wood.
And don'[t forget that wrapping a couple fingers around the wood with your thumb on top of the skew is still a miracle worker at dampening vibration.
