>AAW magazine just had an article on dream lathes. I did not know some of the features existed and am not sure I want some of them.
Some things I would like to have:
A lathe that would take voice commands. Lathe Stop. Or maybe LATHE STOP!!!, Lathe got to 500 RPMs. Tool rest, adjust to the left, tail stock advance, tail stock lock, etc.
And a Chuck: Chuck close, Chuck, lock onto the shaft so that I could say Lathe Reverse and go to 250 rpms.
And while we are at it: Dust Collector, you missed some of that stuff, clean it up.
And if that Sawstop is so smart, why doesn't it just tell me to move my finger?
>Wouldn't it be great if we could put a force field right at the jaws of the chuck so you wouldn't hit them with your fingers or the tools. Or you could position it in front of your face to deflect chips and exploding wood.
Then of course there is the Molecular tool creator. Just push in the right code and it creates a tool from scratch by rearranging some steel molecules.
To my right would be the Automatic laser sharpener. It automatically senses the tool angles and adjusts itself to give the best edge, which is programmable by you so you could have serrated edges or clean razor edges.
Of course my machine would have a hydraulic bed lift like those on a vertical mill. That way I could raise or lower the bed depending on the size piece I'm working on. The tool rest banjo would of course automatically adjust to compensate for the height.
Today I would like to have the Environment simulator so that I could set it for Hawaii and have a nice temperate day to work in instead of this dreary rainy cold.
>Galen I was given one of those for Christmas one year. I could never get it to work. either I was too far away, can't clap at the right rhythm or not loud enough. It would work about 1 out of 3 times. Had the same problems with a whistle key finder. Got a lot of laughs walking around the house whistling. The dog would come but not the keys.
>Barry, almost two years ago I was in Ohio to do a demo for the OVWG in Cincinnati. While I was there, I stopped off to visit the folks at Popular Woodworking, and we filmed a little video on the lathe. The switch on their lathe was broken, so one of the editors stood off camera and plugged the lathe in to make it go and pulled the plug to get it to stop. I said on camera that we were experimenting with a voice command lathe. We all had a lot of fun with it, but I guess they decided not to publish it, maybe because people would undoubtedly start calling in to ask where to get one.
>How about a self balancing headstock? Mounted a hunk of wood out of balance, the lathe detects the out of balance condition and adjust the balance of the headstock to the mounting automatically.
>To be able to take a 1/2 log, knock off the corners (on the lathe)and end up with up to an 18"-20" diameter bowl, spindles up 40" or so, 4" ram travel on the tailstock before the keeper rod nuts and washers get in the way, and auto-feed on the tailstock (would be great but not mandatory).
Hmmm, sounds like a Robust A.B or Sweet 16, or a Oneway 1640 with the outrigger, or a Vicmarc 300.....Nah, I don't ask much.
>I use a foot switch to turn my JET mini on and off. Other functions could be done with a foot switch or two - one perhaps for taking the speed up an rpm increment, reset by the on off foot switch.
Soft start and soft stop would be nice.
How about a light that points where you're looking, you wear an eye piece that controls it. The military has been using them for years.
Maybe an electronic wall thickness device that easily attaches to the turning tool, but doesn't get int he way - self adjusting for different woods and moisture content of course - with a power off feature if you get too close to making the Inside Diameter equal to, or greater than, the Outside Diameter.
Variable viscosity "stuff" that does what LOKTITE does - when something causes the lathe to stop quickly and prevents the chuck from unscrewing itself - put still lets you unscrew a chuck easily.
A captured system set up that would let you move the tool any way you want it - but locks like a seat belt does when there's a sudden problem. This would allow you to turn with the piece rotating in either direction. Think tool rest to support the tool either from the top or bottom.
A hollowing system with built in chips extractors - and high intentsity light - without the heat.
>Voice control would scare me. What if the guy on the radio said something just at the wrong time, like "5000 rpm" when you were leaning close to a large unbalanced log on the lathe?
The wish list on voice control would have to be set up for voice recognition. The advantage would be no other outside control and if you were teaching a new turner he could not alter what you had set up.
I'd wish for the Star Trek items. A replicator that I could get any wood type and shape for a turning blank and any tools or lathe accessories I could ask for. I need the transporter as well to get rid of all the shavings AND any poorly turned item.
>The built-in cooler, with a sensor that keeps the door locked if anyone attempts to place any beverage inside that contains alcohol. Of course the cooler includes a hot plate to keep the coffee and hot chocolate warm, and a warmer for the sandwiches and left-over pizza.
Of course within reach is the control panel for the sirius radio with bluetooth stereo headset (noise-cancelling, naturally). Just below that is the remote for the big screen TV with the shatter-proof screen (no more missed games).
