Stuck Chuck question?
>I have two SuperNova Chucks. They type that work with the chuck key, not the Allen wrench.
One of them had not been used in several months and when I tried, it was stuck. (Not stuck on the lathe, Ruth, don't be showing up with your big wrench.)
Its one I bought on EBAY from someone selling reconditioned or refurbished or seconds or whatever. It has always been stiff, but this time it was very difficult to get it moving. I blew it out. I oiled it and got it going again, but it is still unpleasantly stiff.
Do you oil your chucks? I have not, for fear oil would get on the work piece and also collect dust?
Any suggestions? Is there something to be gained form taking it apart and cleaning the pieces? Is there something to file or sand or grind that might pay off?
Also, the retaining screw that stops the jaws from coming out too far is mangled. Any suggestions on how to remove it?
Re: Stuck Chuck question?
>I don't oil my chucks, but I do wax them upon occasion - I don't wax the holding part - just everything else. I do it more for dust control and to keep them clean. The byproduct is that it does keep them somewhat lubricated.
Tim Geist
Jorge Castaneda~Downeast Maine
>Barry,
Tim Geist, the Teknatool rep in US should be able to tell you how to disassemble the chuck. I have the same but cannot find the manual. I think the Teknatol page has the link to Tim Geist.
Jorge
Haz plantado un arbol?
Bill Turpin in WNC mountains
>Get some aerosol dry lude. Graphite or silicone, it goes on as a liquid but dries to a dry lube that will not contaminate your work.
While you have the chuck apart look for shiny bumps that are the friction points. Remove them with an appropiate tool. Is the mangled stop screw your problem?
>The mangle screw is not the problem. It has no effect unless the jaw hits it at the fully open position.
In the dim recesses of my memory it seems I took the chuck apart at some point. I need one of those ring tool pair of pliers to remove the C-ring. If I could remove the mangles screw, I could crank the sliders all the way out and clean them up, but the screw is a problem. If I remove the C-ring I can get at least three out of four sliders out and can probably get the fourth one out by sliding it across the chuck and out the other side. Reassembly might be tricky though.
Rick_Allen
>File and sanding the chuck parts is OK if necessary. You should take apart a brand new chuck and inspect the parts for any burs or rough parts. File and sand away any burs or rough spots. You can soak the parts in kerosine with a few drops of oil to get a little lubrication going. Be sure to drain and wipe off all parts before you put the chuck back together.
A mangled part should be refurbished to eliminate the mangled portion.
Dick Hines
Dick Hines
>Barry, go to www.teknatool,com. Look up chucks. I think you can find what you are looking for.
>Barry, I wrote about this long ago - I bought a used chuck from a guy that must have been popping steriods because the chuck body was distorted, causing the jaws to bind in the slides. I had to disassemble and dress the chuck body with files and diamond files before it ran smoothly.
If impossible to disassemble, you may have to resort to heat.
I do lightly lubricate the sliding parts with a dry lube.
Mike Mills
Mike Mills
>Here is the link to Teknatool for the standard supernova chuck manual.
http://www.teknatool.com/products/Chucks/Super_Nova/downloads/supermanual.pdf
If yours is the SN2 they also have the manual for it. It tells how to disassebmle the chuck to clean it. Unless it has been buggered up I would not think it would need any filing.
Mike
Ric Taylor
Ric Taylor
>Barry,
My chucks are not SuperNova, but periodically I take my chucks apart and clean everything with WD-40 and a toothbrush. That seems to keep everything working smoothly.
Ric
