Walnut NE and a brave dog
karl jr
karl jr
>I tried a walnut NE today. Boy was that doomed. Now I know that that fat spongy yellow cambium layer needs some CA. No wonder my dog was looking at me kind of funny. She insisted on being right there, though.
Re: Walnut NE and a brave dog
karl jr
I guess I'll start early a.m.
karl jr
>with a revised plan and a fresh bottle of CA.
Re: I guess I'll start early a.m.
>Karl What kind of problems were you having with the Cambium layer. I do use CA when it really gives me trouble cutting and will use it when the wood is older and bark wants to come loose.
I try not to use it if I don't have to. A sharp tool and slow forward speed of the tool will usually cut it cleanly enough to not need the CA. What I don't like about natural edge bowls on Walnut is the different shrinkage of the cambium layer. It always feels lumpy and CA won't help that. The only help for that is to do a twice turned bowl but I haven't tried that with a natural edge. I don't know if the bark would stay on.
ebd
ebd
>I forget which way it is, but i think it's wood harvested in winter holds it's bark and harvested in summer drops it's bark. I could have it backwards so please correct me if you know.
Harvest in spring
Jorge Castaneda~Downeast Maine
>will shed the bark easy.
karl jr
karl jr
>Actually, it's more likely that it was operator error. I removed too much at the top of the bowl (thin and deep) too soon. Then I broke a chunk of bark off. The cambium being so thick and spongy really only exacerbated my own mistakes.
I figured that some CA, carefully applied to the bark would have stiffened the cambium. Then again, maybe I should just be more careful :)
I've done a few twice turned NE's with varing success, but lately I've done them in one go.
karl jr
when the sap is down (fall/winter) is
karl jr
>my understanding.
>CA does toughen up and makes it much less springy. Wipe some finish on the parts that you don't want CA on. Then apply the glue. That way runs won't stain the wood. The early sanding or further cutting will remove the finish. I use lacquer for this even if I'm going to finish with something else. The lacquer dries fast and since I'll be sanding it off it won't affect any other finish later.
The bark is more likely to stay on if the tree was cut when the sap is down, that would be winter.
karl jr
Thanks, John
karl jr
>I tried another walnut NE yestreday. This time being VERY careful cutting through the bark area... roughed to about 2 inches, then a quarter inch at a time. Everything went fine. Reversed it to do the foot, and BLAMMO!
I think the plug in the end of the spindle, the one that seals up the hollow spindle in order to pull a vacuum, got loose and the bowl did that flying trick and broke a bunch of bark off.
Now it's a no bark NE bowl. Some days a guy just can't win :(
