Dealing with chip outs with spalted pen blanks
wilbur
>I tried making some 7mm slimline pens today out of mainly spalted maple pen blanks, and I had a heck of a time with getting blow outs/chip outs at the end of the pen tubes as I was getting close to finished with turning the pen blanks. I've had success with spalted maple with the Wall St. II pen kit, and I've had success with other pen blanks with the slimline pen kits, although I've turned way more Wall St. II pen kits than 7mm slimlines.
Could it just be this particular batch of pen blanks that's giving me trouble here? Any tips on avoiding blowout with spalted maple would be appreciated.
Re: Dealing with chip outs with spalted pen blanks
Russ Fairfield
>The best advice I can give is to learn to turn with a skew chisel, and come into the wood from over the bushing rather than run out of the wood at the ends. The skew will cut with the least pressure on the wood of any turning tool, and coming into the wood puts all of the cutting stress into the wood rather than trying to pull that last chip away from it.
Bill Grumbine (Kutztown PA)
>Wilbur, back in the early 90s I made one spalted pen and it turned out well. Too well, and I got orders for a bunch more. I had a failure rate of close to 90% with the wood chipping out in various places. Then, I started soaking the blanks in Minwax Wood Hardener.
I would cut up a batch of blanks, mark and number them to keep the two halves together, drill them out, and then throw them in a mason jar full of the Minwax. After a couple of days, they would all sink to the bottom, and I knew they were as saturated as they could get. I took them out and let them dry for a few days, and then turned them. Sometimes I had to run the drill bit through them again to clean out the holes, but my failure rate went down to less than 1%.
Dick Coers
>If you aren't using a skew, thin CA can be your friend. Before final end trimming, soak the end grain of the blank with thin CA. For corn cobs which are even tougher, I turn them to within a 1/16" of the bushing, take them off the mandrel, and soak the entire blank in thin CA. You don't want to get much thin CA around the blanks when you have the bushings in. Then tend to stay in!
Another tip is to only turn from the end into the center of the blank. The wood will be supported that way. Center to end cutting will put too much pressure on weak grain.
Marc Phillips
>As the others have said, a really sharp skew has been the biggest help for me. I had a really nice batch of spalted maple and, after ruining 2 in a row, I quit trying. Then I learned about sharpening my skew chisel and also honing it with a stone and I was able to turn every one of those blanks (and many more since then) with only one small repairable chip out.
wilbur
>Thanks for all the tips. I was using a skew chisel, but I wasn't coming from the ends into the middle. I will give that a try today.
Success! (somewhat)
wilbur
>I got my pens done. The tip about coming in from the ends helped, although this still seems a bit counterintuitive to me, and I was more obsessive about keeping my skew chisel sharp. It also probably helped that I wasn't as frustrated by the blowouts from yesterday. Looking back, as I got more blowouts, I was getting more frustrated, and probably started pushing my skew chisel harder, which certainly wouldn't have helped things.
Anyway, here's the results of my handiwork. Thanks for all the tips!
Re: Success! (somewhat)
wilbur
>P.S. I say "somewhat" because all of these pens would have been spalted had I not blown out the blanks that I did. Still, I think they came out pretty nice.
Carol Reed - home in Strawberry
>Indeed they did!
BarbS
Those are nice.
BarbS
