Question for Andi and other jewelry makers/
>I have made some earrings. Little wooden bird houses and some like small tree ornaments. I just glad people don't have three or four ears. Mine don't match as well as I would like. I suppose I should be glad there will be a head between them.
The question is, I shellac a good finish for them? Or would you go with lacquer? Or what?
Re: Question for Andi and other jewelry makers/
Steven Antonucci
Sand them to infinity, lacquer and buff
steve antonucci
Re: Question for Andi and other jewelry makers/ *LINK*
Dick Coers
>I use a spray enamel that I get at Lowes. Less than $5 a can. They call it an oil modified alkyd. I thought about water resistance in case the wearer gets out in the rain or snow. Lacquer doesn't do real well in water. They list this as a non-yellowing formula good for exterior.
RustOleum spray enamel
AndiWolfe
>Barry - I prefer a 50:50 mix of Danish oil and mineral spirits.
I hand sand to 400 grit, then sand using 3M bristle brushes - up to 400 grit, then buff with a hair wheel (3/32 mandrel). I use a micromotor carving unit for the last two finishing steps I just mentioned. This finishing sequence puts a nice sheen on the wood, even without a finish. The oil/mineral oil mixture soaks in and gives a good finish without the high gloss.
For turnings, once you get the sanding done, I'd do a bit of buffing with a scotchbrite pad - the white one works well, and then use the 50:50 oil/mineral spirits finish. Apply the finish off the lathe - liberal coat, let it soak in, wipe off.
Post a pic - I'd like to see what you made. Andi
AndiWolfe
>Umbrellas or a hood on a rain coat do pretty well at protecting earrings ;-)
