>I am new to this site so I am sorry if this is dumb or been discussed before. I have a metal lathe and would like to make a large wood screw (say 2")like those used in a vise. I have tried cutting acme threads in oak but the wood was too chippy. Can this be done on a lathe? What is the best wood. Are there wood lathe attachments (I have a basic wood lathe) for cutting threads?
>The problem is 2 fold. One is the cutter and the other is the wood. You need a good hard wood that will take threads. Boxwood is the best, Osage Orange and Cocobolo are other woods I've tried that work well.
Metal lathe cutters were not designed to cut wood cleanly. You might be able to modify the cutter to get a better cut.
Nobody I know makes an Acme thread cutter or attachment. If you look at the rotating cutter assemblies that the ornamental lathes use it would not be hard to build a cutter that would do Acme threads. These have a simple mechanism and motor that drives a spinning cutter. That could be attached to your cross feed table and the set up on the proper screw feed rate would give you the threads per inch feed. I plan to build one of these some day after I win the lottery and no longer have to work to feed my face.
Beal sells a router attachment that will cut threads but they don't have Acme threads. I've put the link below.
You can also buy wood threaders from companies like www.woodworkerssupply.com These are like Dies and won't cut a clean thread unless the wood is very hard and of course they don't make an Acme thread either.
There was an episode on The Woodwright shop where he shows how to make a threader. That could be adapted to make an Acme thread but I don't know how cleanly it would cut.
>Dry dogwood and bradford pear are also good, fine-grained, tough woods. (Our friend Ralph Watts said bradford is the strongest wood he knows for things cut or carved regardless of grain orientation - his favorite for carving long tendrils and such. Don't know how it moves with humidity, though.)
I wonder, is there a reason Acme threads are not historically used in wood? Since the sides of the threads are nearly vertical, would excessive clearances be needed to keep things from binding as the wood moves?
If so, I wonder if stabilizing the wood with the pressurized process (or dousing with CA) would help, or beginning with a blank of glued-up pieces.
>Acme and square threads in wooden screws were fairly common for noth knee and shoulder vices in antique workbenches, but the screws were a lot bigger than 2" diameter. More like 4" diameter and 1/2" pitch was fairly common on those I have seen, and the wood looked like a hard maple. All of them had some means for adjustment of thread clearance in the nut to allow for wear.
>Wood behaves and cuts a lot differently than metal (duh) and than makes the challenges of adapting threads that are pretty easy in metal to woods. Because the shaft of the wood screw is longitudinal for strength, the threads are leaving end grain on both sides -- that heads one towards some of the very tight grained woods so the threads do not chip. It also points towards very coarse threads -- like 4 or 6 per inch as fine threads. Most metal lathes, especially the smaller one do not head towards that coarse a thread. The metal cutter that shear steel, brass, alumimum tend to tear wood.
Threads on the screw can be laid out and carved like barley twist patterns.
Can you do it on a wood lathe -- yes, but probably not cleanly, and not easily.
Can you gear up to do it with a router, especially if you are willing to grind bits, you bet - but expect to do jigging.
Up to the sizes available, the Beall wood threaders can get the job done, but tend to tear out unless using very very good wood. And the wood lathe is ideal to make billets into round stock to fit the larger sizes. (I have Jerry Bealls threaders and have used them with moderate success - suggest the dogwood and persimmon as really good woods along with hop hornbeam (east coast ironwood)).
>My book, "Making Screw Threads in Wood" describes how to layout and cut coarse wood threads by hand. This is one option to achieve what you want. If it is a long screw, it will be difficult to maintain nice even threads when cutting them by hand.
Since you have a metal lathe, I think it would work better if you could replace your cutting tool on the metal lathe with something like a Dremel or similar tool with a square ended cutter the width of the groove in the thread you are trying to cut. Then with the gearing set to cut the thread you want, you should be able to (you might say) route the threads as you slowly rotate the lathe by hand.
As others have noted, the best wood for a 2" wood screw would be English or European Boxwood. However, Eastern Hard Maple would also work, but is not as strong as boxwood.
