Bottle Stopper Transport
Nick Tuzzolino
>I need suggestions on how to transport bottle stoppers without them falling all over the place. I currently just use boards with a 1/2" hole. Not good. These are not for craft shows and such, but people at my gym and places like that want to see (and buy) stoppers.
Would you drill a step hole in a board or just use small plastic bags, or?? Specifically Ruth Niles' stoppers. I am talking about 15-20 stoppers and would like to carry them in just a grocery bag or? TIA Nick
Re: Bottle Stopper Transport
Re: Bottle Stopper Transport *LINK*
keith zimmerman, Normal, IL
>I use 3x4" black velvet bags I bought at PaperMart.com. Stoppers made with Niles stoppers fit perfectly.
keithz
Papermart
Colin
>My wife stitched me up a cloth roll with pockets that the stoppers go in from alternate sides just like a roll for files or gouges / chisels. Works well, holds 10 in a roll and I take 2 rolls with me when I go to show someone.
Don Evans
>Why not just take a piece of plywood, 1/2" thick will do, maybe 10"x10". Put stubby legs made of 1/2" square stock couple inches long, one under plywood at each corner.
Find a card board box that this will set down in. Drilled holes in the plywood hold the stoppers. Or find box and make plywood fit it.
As long as it isn't tossed around, kept upright it should work fine. Just opening the top of box allows people to look and examine.
It's simple and for what you discussed I don't see needing anything expensive or fancy.
A little fancier? Paint the plywood, legs AND the box flat black.
Inside and out.
Don
Stuart Johnson
>With everything being shipped with Styrofoam packing you should be able to come up with some pieces that can be cut to size. A bottom piece with holes to hold the stoppers and a top piece to keep them in place when transporting.
THANKS
Nick Tuzzolino
Great suggestion, Don and...........
Ruth Niles
>I saw someone use a large bowl filled with white peas or beans. The stoppers stayed upright wherever you pushed them in. It was very attractive and held as many or few stoppers as needed.
