Duplicators
Bill Youngblood
>Does anyone have any experiance with spindle duplicators for use on a Powermatic 3520A? I'm primarily looking for quality rather than price. Thanks.
Duplicators
Bill Youngblood
Re: Duplicators *LINK*
>I am currently playing with a Vega duplicator. see the link below. I believe it's the model D-36 but I would have to look to be sure. I'm still pretty new at using it but I'm impressed. I have never used a duplicator so I don't have any comparisons with other units. It came with 2 cutters, HSS and carbide. The carbide definitely cuts cleaner and would save a lot of sanding time.
It does not cut as clean as you can with a good cutting tool but is way faster than turning the parts from scratch. I do a fair amount of duplicating parts by hand but only in limited quantity. I'm thinking about marketing myself to a few local companies to do higher quantity duplicating. I think this tool will do the job. It might not be the best tool for really high quantity. For that I would think you might need to look at industrial duplicating machines that are probably 10 times as expensive.
I'm planning another batch of 36 or more small spindles to see how that will go. I'll report on my findings after that.
http://www.vegawoodworking.com/
Re: Duplicators
Bill Sams
>Here's a photo of mine with 48" duplicator. Since this pic was taken I purchased another 4' section which now allows me to duplicate up to 97".
As John said the cut is not as clean as with turning chisels, but for roughing out, it's great. Just use your hand chisels to clean things up and sand as normal.
There is a learning curve as with everything, a little finesse is needed to shape small beads, ie 1/4".
The optional "slender turning attachment" may be something for you to look into in doing small diameter work.
Re: Duplicators
Bill Youngblood
>Thanks Guys. It's great to know that when a turner needs help, it's only the push of a button away. Thanks again.
