turning with a chainsaw. *LINK*
john lopez
>interesting tailstock extension idea.
http://www.youtube.com/watch?v=ydDQQQww1AA
john lopez
tail stock extension
>When I had my Nova 3000 I had to turn a 54" lamp. My mini lathe was is a Nova Comet which uses the same bed extensions as the Nova 3000 so I turned the Nova comet around and clamped it with angle iron far enough away from the 3000 to give me 54". I then mounted the Nova 3000 tailstock on the Nova comet in reverse. I jury rigged a long tool rest out of wood and angle iron.
I'm sure I'm not the only one who has done something like this and that video proves it. Anyone else out there rigged up something unusual on your lathe.
Re: tail stock extension
Bill Grumbine (Kutztown PA)
>Back in 1999 I turned a mast for a sailboat I was building between my Nova 1500 and my Vicmarc mini. The mast was 14' 2" long. I've got some pictures somewhere, but I would have to go look for them. I lined the lathes up by eyeballing down through the tapers on the mini, made a steady rest that clamped to my jointer, and went at it.
>I have a DVR I bought with the short bed that came on it. Needed a longer bed to turn some table legs. Bought a bed extension but the lathe is mounted on a cabinet that is just long enough for the short bed. Tim Geist (the Nova Guy in the US suggested I just bolt the extension on and let it hang out in the air. I did and it has been that way for about three years. Its strictly supported from the end. Seems to work fine.
>Barry I now have a bed extension for my Nova Comet. I'm thinking about building a hinge so I can leave it down most of the time and when I need it just lift it in place. It's either that or make some sort of cam lock so that I can drop it in place and lock it down real simply.
Re: turning with a chainsaw.
Bob Macgregor
>I seem to recall Nick Cook turning a very large oak log into an hourglass-shaped coffee table between two Powermatics(?) bar-clamped together. The video was on an earlier incarnation of the Woodworking Channel, but doesn't seem to be there anymore.
BOB
Re: turning with a chainsaw. *LINK*
Neil Longhenry
>Another Turner that uses a Chainsaw LINK
Virgil - The Process
Tery Scott
>Hi John Ill see if I can find the link but I came across a u tube video once of a guy that was turning 6m veranda posts and he had the head on one part of the bead and the tail stock 6 metres away with only one section set up in the middle with a steady mounted on that.A 3000 was used
Steve Kubien
>While admire the resourcefulness of getting his lathe set up like that, plus the cart and the simple logistics of this, I see a Darwin Award in his future using a chainsaw like that.
>I couldn't figure out why he did not just cut the rings into circles before he stacked them. Seems like that would be a lot easier than beating it to death with a chainsaw. I also wondered how he made the cuts to create the door.
Somehow I felt sorry for the lathe.
Jorge Castaneda~Downeast Maine
>John,
I made a bed with 65" posts in the headboard, turned on my Delta Midi and one Delta extension, I made a plywood box long enough to connect the two and give me the needed distance, had the tailstock on the extension bed and had to rig a very long oak tool rest, looked weird but did the job.
Jorge
Bill Crommett
>Several years ago I turned a handrail for my daughters boat out of walnut and cherry. It was +/- seven ft. long so I did it on my old Shopsmith by bolting the tailstock to the wall of the workshop and blocking the Shopsmith about six feet away. It turned out O.K. but there was a lot of spring in a 2.5 in dim. pole seven ft. long so I built my first steady rest.
probably harder to align the rings?
steve antonucci
>I don't do segmented work, so I'd just be guessing, but I assume that having the points would make it easier to align your rings when you glue up. I personally thought he should have just turned it, but it looked an awful lot like he was turning below center, so he probably spend a lot of time cleaning up tearout. It may have just been the camera angle, though...
Steve
Clay Foster
>One time at Emma Lake we clamped two One Ways end to end to do some long turnings. Both tool rests were left on so two people could turn at once.
