Question about acrylic - pen turners?
AndiWolfe
>I made some earrings from acrylic this evening after slicing up an acrylic pen blank. I don't turn acrylic, but I remember Bonnie Klein uses some special abrasive soaked in water for polishing her acrylic boxes. Carving presents a different kind of challenge. I was able to use 3M bristle discs followed by a bristle brush to smooth out the carved surface.
My question for pen turners who use acrylic, or anyone else who uses this material for turning, is - what do you use for polishing the surface after going through the various abrasives to smooth or seal the surface?
Re: Question about acrylic - pen turners?
Greg Haugen
>Andi,
When I've turned acrylics I've used a couple of different abrasives. I've used the cushioned Micro Mesh pads, dipped in water. I've also used a "newer" abrasive that is a pad similar to micro mesh that is made for acrylics and solid surface, also dipped in water. Barry Gross (bgartforms.com) carries it, as does Anthony Turchetta (thegoldennib.com). The pads are a "pastel" color and has 6 grits. Either way, I followed it up with a buff with PlastX, a plastic polish that is available at auto part stores. I recently saw a video from Ed Davidson where he's turning some of the acrylics that he casts himself. If I recall correctly, he wet sanded to 1000 grit and buffed with white rouge on a buffing wheel. I tried it and got the same, if not better results with the wet sand to 1000 and buff with white rouge, than when I sanded to 12,000 grit and used a plastic polish.
One of the two methods, or a combination should work.
Greg H.
Sean Troy
>Don Pencils PL buffing product works fantastic. You could also use 3M's Finesse It polish and buff.
Automotive rubbing compound
Rick_Allen
>Sand to 320 then use automotive rubbing compound,
Many thanks for the suggestions!
AndiWolfe
>I really appreciate the input. I've ordered some buffing bristle brushes and white rouge from Rio Grande. I'll try some of the other ideas presented here as well. The little bit of buffing I was able to do yesterday gave the dangles a nice sheen, but I think I'd like a bit more of a glossy finish to these earrings.
Lyle Jamieson
Re: Many thanks for the suggestions!
Lyle Jamieson
>I have done pens 15-20 years ago and never got too excited about the process. But when I was in Texas for SWAT I got to know the pen guru and saw some VERY exciting things that can be done with pens. Don pours his own plastics with all kinds of exotic things like rattle snake skins etc. He would surely have a good polishing method. His pens are unbelievable. don@redriverpens.com
Re: Automotive rubbing compound
Jonathan Hess
>Try the white version of compound after final sanding. Apply with a damp,not wet, soft rag. It dosn't take much. I get a mirror like finsh. High rpms and go back and forth as you would with triple E. Wipe off excess.
Re: Question about acrylic - pen turners? *LINK*
Ed Davidson
>Andi,
Here's the link to a plastic pen turning video how-to that shows my preferred finishing method - wet sand and buff. The process works equally well on home-brew poly resins and professionally cast acrylics.
Turning & finishing plastic
AndiWolfe
>Thanks, Ed - very helpful.
