REAL MILK PAINT
Hey, Molly Winton, a ? or 3
Carol Reed - home in Strawberry
>I am building the Wood Vaporizer and a couple of the burning pens in your booklet.
I have the battery charger, dimmer switch and Radio Shack terminals rounded up thus far. I think I remember you saying you use a 1/4" phono jack to plug in your pens. I read somewhere that they are not rated for 10 amps and will get too hot. The solution presented was to use banana plugs. I am mystified as to why they would handle more amperage.
(BTW, past work experience working with circuitry in both DC and AC, so not a total doofus, but a rather rusty one!)
I got a small chunk of cocobola for the palm pieces and some bocate pen blanks for the pen style. I was looking for wood species with a high specific gravity, as these both are. You did suggest a very 'dense' wood to help handle the hot pen issue.
What is your experience?
And for anyone who has built the Wood Vaporizer, what kind of pen plugs did you use, and what was your experience?
Thanks!
Re: Hey, Molly Winton, a ? or 3
Re: Hey, Molly Winton, another ?
gtwilkins
>Molly,
I remember a post from a while ago that you had a man that you got your nichrome wire from and he had a starter pack with some different sizes in it.
Who is he and does he still do it?
Thanks, Trevor
Re: Hey, Molly Winton - not Molly, but...
>Yes he does. His name is Bob and you can email at mtebob@sbcglobal.net. The kit is $12.95 including shipping, and no tax if you are out of state. You simply send him a PayPal payment at that email address specifying the Molly Winton kit, and Bob's your uncle! You can email him first if you like. I did.
>Carol,
In case there is confusion: There is a big difference between the "phono" jack and the "phone" jack. The commercial woodburners I've seen (and I have one) use 1/4" "phone" jacks - these have a 1/4" cylindrical shaft and come in mono (what you need) or stereo. Connectors named "phono" or "RCA" are the type commonly used on cables that connect audio and video devices together. Phono connectors have a small central conductor and an outer petal-like shell; these can't handle much current.
Banana plugs can handle more current because of the increased contact area and the way the wires are usually connected. Banana plugs are often used in power supplies and other industrial applications.
Yup, that's the info. Thanks Carol!
Molly Winton
I'm not much help here....
Molly Winton
>I've yet to hook up my battery charger, so I really can't help you with this info. My instructions show to hard wire the hand piece to the jumper cable lines. I've heard of some folks converting that to a plug (phone jack as John K says), but am not familiar with how to do it.
Sorry I can't be more help.
>John, my bad! I meant the 1/4 mono plug. The question remains. Which would be better, the 1/4" mono plugs like the lower powered commercial burners use, or the banana plugs to handle the higher amperage of the battery charger? I plan to dedicate the new battery charger to this task, so drilling holes in the case is no problem.
Re: Thanks Carol, NM
gtwilkins
>I'm not familiar with the currents here. The 1/4" phone connectors are readily available (caution, quality varies). Another advantage might be the ability to use a commercial pen if necessary (if the current requirement can be matched).
One easy (and safe) thing to do before drilling the final holes in the case is connect a phone jack and plug in line (in the air, perhaps loosely wrapped with tape) and turn the thing on and see if it self-destructs.
Doug Wolf
>Here is the Woodburner I made after seeing Molly at AAW in New Mexico last June.
Doug Wolf
>Here is the rear veiw.
Doug Wolf
>Here are the cherry pens I use with stereo phono plugs. They don't get to hot to hold. JB Weld secures the terminals in the wood.
Sorry for the three seperate post but I couldn't put three pictures into one.
Doug Wolf
>Picture
Brad Vietje
Re: Yup, that's the info. Thanks Carol!
Brad Vietje
>Hmmm, This looks cool (hot?). Molly, I'll contact you off-list for more info.
Safe spinning,
Brad Vietje
Newbury, VT
Dang, Doug!
Molly Winton
>That's what I want to do with my battery charger. I just don't have the know-how. Would you just run up here to the Pacific NW and snap mine together? I'd really appreciate it.
Re: Dang, Doug!
Carol Reed - Strawberry, AZ
>If Doug can't make it, let me know. I'll make you a box and you can get a battery charger for it and simply hook it up like you would on the car. Then plug in one of your handpieces and have at it!
Phone, Phono, Banana Plugs *LINK*
charlie belden
>If you need photos of the differnet kinds of plugs, John K. Jordan provided the ones shown on the attached link - with more stuff about making a battery charger based wood vaporizer.
NOTE: The "non-solid state" battery chargers are getting harder to find. Sears apparently is closing out the "manual" versions for under $40.
DIY WoodVaporizer Stuff
