ADVERTISE HERE - FREE TRIAL
Jet 1642 lathe 220v plug?
Carol Reed - home in Strawberry
>Does it come with one? If so, which configuration?
Thanks!
Re: Jet 1642 lathe 220v plug?
Greg Haugen
>Carol,
The 1 1/2 horse is 110 V and the 2 horse is 220 V. Is that what you're asking?
Texian
>Mine did not come with a plug. Must buy one to fit your outlets. The 15 amp rating will handle 2 hp, 220V.
Re: Jet 1642 lathe 220v plug? *LINK*
>Carol,
The manual (at the link below) says no - add your own plug (typical with 220v devices).
If you are like me, you may be interested in reading the manual before the lathe comes. I found it on the Jet/PM web site.
Jet 1642 manual
>Thanks, John. I have downloaded it and will get into it later.
I didn't think the 220v version came with a plug. I do have a 220v dryer plug, outlet, and box on hand. I will use that. And I will put the switch in-line to completely shut things down.
Thanks!
John Veerkamp, Western Mo
>Carol, the dryer plug & outlet is rated for 30 amps. It is much heavier and cumberson than 15 amp. Each amperage rating is configured differently so as to keep someone from pluging in higher demand devic=ves into lower capacity circuits. The dryer plug will certainly work, but my advice st to get the 15 amp plug and outlet. Should cost less than $10 for both.
John
Dick Hines
Dick Hines
>Most 220V tools don't come with a plug. Ther a bunch of different plugs so they leave it to the customer to supply them.
When you buy your plug make sure someone has not switched the plug in the package. I got home wad was dread to hook up my vacuum pump and the plug in the package did not match what was on the package. I was POed. I had to go back to the to get the right plug.
The AAW used our club lathe at the Richmond Symposium and when we got it back they had changed the plug. That caused us a fast trip to a big box store for a new plug so we could have a demo that night.
Don't use a dryer plug.
>Not that it won't work - it will. But it is serious overkill. Get a 15 amp 220 V plug and receptacle at a local electrical supply place. The one I got for my bandsaw has two flat horizontal blades and a grounding pin.
Re: Don't use a dryer plug.
>I yield! LOL. Its on my shopping list for tomorrow.
