>I had a bright idea this past weekend after making my first batch of wine. My son last Christmas gave me a wine making kit and I thought it would be good to use it before this Christmas. One of the steps during this process was to de-gas the solution. There are three ways to do that; 1.) Big spoon and stir till the bubbles stop (to lazy for this), 2.) Have an attachment for the drill (did not have) 3.) Pull a vacuum till the bubbles stop (alright).
I was sitting there with a hand pump thinking this is crazy when I remembered my vacuum pump on my lathe. The pump only took 10 minutes while I sat there thinking how sweat life is when a plan works.
So the moral or the story is; wood turners should get to know home wine makers (without a vacuum pump) and team up. Turners get a few bottles of wine while the wine makers get de-gassed and maybe a bowl.
>This would be a problem in some places. State law here says you can make 1 gallon at the time for your own consumption. Selling or trading for a bowl as example would be "boot legging". Highly illegal.
>I am not a winemaker but have been a homebrewer of beer for over a 15 years.... ...and have been working in research laboratories and around vacuum pumps for about 30 years.....using all manner of glass vessels.
Pulling a vacuum on glass vessels not meant to withstand such "backwards" forces can result in an implosion or other catastrophic failure. In graduate school I once violently imploded a glass vessel (used as a trap) because the vacuum level was far too high for the walls of the vessel to withstand the total atmospheric pressure once evacuated. We were finding glass shards around the lab everywhere for many months after the episode, and that day I even picked a few pieces out of my jeans (...and one piece out of my leg) following this "learning experience".
The level of vacuum required to de-gas a liquid will vary depending on the situation (concentration of solutes, temperature, agitation, time, etc.), but I would like to caution you that strapping a vacuum pump to a glass vessel (assuming you are using the 'standard' 5 gallon glass carboy as your fermentation or conditioning vessel) could be a lesson in disaster. There is a real possibility of breaking your carboy under vacuum, as well as losing your wine all over your 'local environment' (not too bad with a chardonnay, but could be stain-disastrous with a burgundy!), let alone the extremely sharp glass shards of a broken carboy. (...and I know ALL ABOUT THIS from a personal experience with a broken carboy, half-filled with beer! Fortunately it broke in a sink and not on the floor.)
There may be a reason why it is recommended that agitation-based de-gassing is recommended for winemaking. If you must use a vacuum, be sure its at a relatively low level (....perhaps 10-15 in Hg or less??). If you are waiting for the bubbles to stop, you may be watching and waiting for an (inverse) bomb to do its thing.....
>You could draw a low vacuum with any pump by adding a hole somewhere in the line - a tee with an adjustment valve, a hole in a brass tube with a sliding or rotating sleeve for adjustment, ...
I agree that vacuum can be dangerous, especially in a vessel with some side or bottom flat and especially glass. When they had to be transparent, chambers we used were made of plastic and either spherical/hemispherical or thick windows (1"-2") in a metal chamber.
>Thanks for the saftey tip. The rubber lib is very thin and will collaps if I pull to much vacuum, and in fact it has several leaks which is why the hand pump does not work. I have the pump turned very low. If I did not it would suck the bubbles into the hose since the wine is within an inch of the top.
>Actually it did Don, he went to prison for it. Junior wasn't actually a "boot legger" he was a hauler. His daddy was the maker and asked Junior to go down and light the fire one day and the Fed's were waiting and got Junior.
Did you know that Ronald Reagan gave Junior a pardon when he was President? Therefore negating Juniors felony status.......
