C1 carbide tool
>Today I found a good use for the C1. I was making a 19" table top that had to be flat on top. it is 3/4" thick. The C1 does a good job of flattening it if you put the tool rest parallel to the table top. The slight radius at the tip makes it easier to use than a flat scraper. I've used a heavy large round scraper before and this works at least that good.
It doesn't leave as good a finish as a gouge does but it's really difficult to get a perfectly flat surface using a gouge. I used a flat nosed scraper tilted about 45 degrees to a shear scraping angle to clean up the slightly torn grain look left by the C1.
