What type of lighting would you recommend?
Ilya Z
>When bowl turning on a few occasions, I noticed that I really needed some extra light, especially when turning the inside of a bowl. What type of lighting would you recommend that would be bright, flexible, totally portable and not too bulky? In the shop where I turn there was once a simple desk lamp with a magnetic base. The main problem with that one was that its neck was too short and was not flexible so the lamp often got in my way when I placed it too close to the bowl. Are there better alternatives? Also, have you ever tried using one of those headlamps they sell at camping stores? They seem to be pretty bright and they are definitely portable, but are they sometimes hard to aim at some small spot without tilting/turning your head in an awkward position?
Thanks much.
Re: What type of lighting would you recommend?
John Scheideman
>I bought the type of light that dentists use. You can turn it to almost any angle. You can attach it to the ceiling, wall, or, in my case, to a post that is attached to the outside of the lathe.
John
Ilya Z
>You mean the large lamps that usually hang above dentist's head? That's a great suggestion for future if/when I ever get to have a shop of my own. But I currently turn at the local ww shop and so I need something that I can bring in and carry out with me every time.
>I use a little clip on light I bought at K-mart. It has a little spring loaded clamp on it and a high intensity bulb. I think it was about $20 but I don't actually recall. The bulb lasted a long time, but when it finally died it was about $8. They did not have any at K-mart so the guy took the bulb out of the display and gave it to me. Next time I found them cheaper than $8 at Radio Shack.
Look up Moffat lights also. They make a bunch of them, some with magnetic bases and some with clamps.
I also have a dentist light I got free form a dentist office they were demolishing. Its one of the old style ones. I called the company and a bulb for it is $80. (I don't need one, but that was a shock. The reflector is losing it's silvering. They wanted $800 for the reflector. I was stunned. They said the whole light sold for about $3500. I have two of them.
Wonder what John paid for his?
I still use the little clip on high intensity light.
>I love the Moffet lights. I have 3 of them. I believe Oneway sells them now. Woodcraft might also. The come with a magnetic base and also a quick release base. This makes mounting them easy.
Re: John, is it this one?
>That's it. Boy have they gone up in price. I paid $39 for mine. I still think they are worth it. I've used them extensively. I just replaced the 100 watt bulbs with 70 watt flourescent. They give a good bright light and you can easily position them at an angle to better see the sanding scratches.
>I like these too. I have the mount for one bolted to my bandsaw.
Cyril Griesbach
>John, I could be wrong but I think the magnetic base is and extra cost.
Don Evans
>The Woodcraft ad that is linked in other post indicates that the magnet base IS included along with the other two type mounting brackets.
Treeline sells this same thing with a magnifier lens on the end instead of the light which I purchased from them for checkering and some carving work. They sell the magnet base and a bench edge clamp base for it but they sell these two separately. I didn't know it would come with the other two (angle and one that takes 3 wood screws) I paid $14.00 extra for the magnet base and ended up using the small one that uses 3 screws.
So in all, there are 4 different bases one can get for it, maybe more?
www.treelineusa.com to check out the magnifier. It's identical to the light shown excess what is one the end of the arm, light verse lens.
Don
Re: Cyril, answer to your post
Don Evans
>Cyril, see my post just above, I was trying to respond to your post but it ended up in wrong spot..
Don
Re: What type of lighting would you recommend? *LINK*
Stuart Johnson
>I've been thinking about a dock light like one of the one shown on the link. I'm pretty sure I can build one out of square tubing from Lowe's and spend a lot less. The only part I'm not sure about is what type of bracket to use to mount it to the wall.
dock light
Ilya, here's another...
GaryG in MD
>I use this one from Enco. It's a halogen bulb and mounts via a handy vertical rod into an easily removable c-clamp that can be screwed right onto the ways of my Jet 1236. It's spring loaded and moves (and stays) in any direction. I often use it at a low angle, along the axis, to show the subtle (hopefully) tool ridges. ...Gary
Switch & Dust
charlie belden
>I bought two of these lamps at a woodworking show "special price" - two for $100 - they "listed" at $59 each. Attached the Click On bases to the back of my lathe bench - one near the head stock and one back by the tail stock. Bought and extra Click On base and mounted it in a special "dog" to fit anywhere on my woodworking bench - cutting good dovetails requires good light.
Great light sources - except for the switch. Apparently sawdust gets to it easily and one stopped working - even after blowing it out with compressed air. Order TWO "switch repair kits" - figuring if a switch went out once - likely one will go out again.
No big deal to replace to repair the switch - if you have the repair kit - but inconvenient as hell when a switch fails and you have to order and wait for a repair kit.
Re: Switch & Dust *LINK*
>Is your's a genuine Moffatt? The Moffatt lamp I have protects the switch from dust with a rubber boot. If I remember, I bought mine from Iturra Design, the bandsaw people. (866-883-8064)
http://www.moffattproducts.com/
Re: Switch & Dust
charlie belden
>They're the real McCoy - and when I called them to order the repair kits I asked if they had a dust proof cap or whatever to protect the switch from dust getting in them. I was told on the phone that they didn't.
Got a part number?
Re: Switch & Dust
>You might try Iturra. Or make a rubber boot from thin sheet rubber like the wide stretch bands used in physical therapy.
