Question for Russ or anybody who knows
>You mentioned an oil for bowls that will not turn rancid. I think it was Safflower oil. No allergy problems. Or was it Sunflower? Thinking of using it on cutting boards.
Re: Question for Russ or anybody who knows
Greg Haugen
>Barry,
I really like "danish oil" by Tried and True Wood finishes. It's available at Woodcraft and Lee Valley. Don't let "Danish oil" scare you. There's no thinners or driers in it, it's simply polymerized linseed oil. It's food safe wet or dry. If you apply thin coats, it will dry/further polymerize in a day or so. I used to use Mahoney's oil, and since switched to this since it doesn't darken the wood with age or anything like that. And since it's Linseed/Flax oil it doesn't raise the "red flags" with some customers like "walnut oil" does. It's a "satin" sheen finish which I like for utility items. For a higher sheen they have other finishes, still food safe, with beeswax or natural resins added.
I've also used pure "tung oil", the "real pure" oil. Applied it thin, and been very happy with it as well.
Just my two cents.
Greg H.
Re: SUNflower Oil
russ fairfield
>The product made bt Hain is available at most grocery stores.
Does it dry Russ?
Greg Haugen
Re:Mineral oil for food related items!
Jamie Donaldson
Ken Oakley-Sunny St. Cloud,Fla
>That's what I use
Jorge Castaneda~Downeast Maine
>Barry,
I use walnut oil or hazelnut oil. both do dry and do not get rancid. I never had a problem or complaints. Sometimes I use bees wax right on top of the oil, actually several coats of oil, allowing it to dry before the next. People like it and keep buying them.
I hear that sunflower oil is good too, some people use mineral oil, but that is just like using vaseline.
Barbara Gill, Remlik VA
>Wasn't there a study that showed that cutting boards treated with mineral oil were more likely to harbor bacteria than those left natural? I know the pitfalls of studies and statistics but it is something to think about.
Re: SUNflower Oil
russ fairfield
>Sunflower Oil is a non-drying oil.
As a general rule, seed oils don't "dry". Nut oils do. Some seed oils such as Flax seed (linseed) and Soybean Oil can be forced into becoming a drying-oil through physical modification and the addition of chemicals.
Most non-drying seed oils turn rancid with age. Sunflower Oil does not.
I use Sunflower Oil because it has a pleasant odor, tastes better than Mineral Oil, makes an excellent salad oil, and sounds better to a potential customer.
Most people around here associate Mineral Oil as something they buy by the gallon and use as a laxative for horses, and not something they want to eat. Sunflower Oil solves that problem.
