Sandpaper use
>I know we talk a lot about turning with razor sharp tools and being able to start sanding with 2000 grit sandpaper (yea right). It is fun taking your time and use the tools to their best advantage and it's badge of honor to be able to start sanding with as high a grit as possible.
There are advantages to this. Extremely fine details can be destroyed by even minor sanding. A good example would be my miniatures. If I start below 320 and sometimes even 400 I can ruin the details I try to achieve.
On the other hand you have look at what you are trying to achieve. I learned from a production turner friend who thought nothing of turning 500 or more cedar apples in a week that it was a waste of time to spend an extra 5 minutes cutting with tools. He would rough it out to shape in about a minute leaving tool marks but little tearout, and then start sanding with 120 grit. The wood was soft enough and there weren't any details to worry about. He would make an apple, that really looked like an apple, sanded and a layer of sanding sealer applied in about 3 to 5 minutes.
Nick Cook turns only Cocobolo wine stoppers. These are his production items and he turns them in 3 minutes. He cuts them clean enough that 120 is easily his starting point. You could push the tool a little slower and sharpen more frequently but it would slow him down. He also skips a grit or two and I believe he goes from 120 to 220. He knows exactly what it takes to get a quality product as fast as possible.
When I turn my simple wine stoppers I turn them as quickly as possible and usually start with 120. It is faster doing that than spending the extra time it takes to cut cleaner. On the other hand my detailed wine stoppers are turned to the point that I just barely need to sand them and start with 400 and 600. The exotic ones get sanded and polished to a higher shine.
What I'm saying is we should strive to learn to cut as cleanly as possible. It leaves the wood in better condition and saves sandpaper. It saves fine details and leaves crisp corners. If your doing production items you have to make some decisions on what is most important for that product. Production time is crucial and it may simply be faster to turn them a little less carefully and just start sanding with a lower grit.
Those are my observations. I'm definitely open to different styles of turning and different opinions.
